| Jeff73 |
Jul 3 2006, 07:40 PM
It may be short, but it sure is small!! ![]() ![]() Group: Members Posts: 111 Joined: 13-June 06 From: Bremerton, Wa Member No.: 6,220 |
After finally getting into the car. I got it running yesterday. Felt good. I was going to move it, but the brake pedal is stuck. Don't know if it's just the pedal or if it can be worse. Oh well, plan to replace all of the brakes anyhow. Anyone know where I can get the pedals rebuilt? Also, after moving it I found out there is a gas leak somewhere. After further investigation it is the fuel line under the tank. Anyone know where I can get new lines at?
| Allan |
Jul 3 2006, 07:42 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Dude ya got it running. Get the brakes sorted out (which is minor compared to a good running car) and go for a drive...
Get those brakes fixed first. |
| BigDBass |
Jul 3 2006, 09:02 PM
Dumb Question Champion ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
| jim912928 |
Jul 3 2006, 09:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I'd fix the fuel leak first before it goes POOF!
| sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,094 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
try pulling the pedal back, see if brakes release . when the pedal bushing go bad the pedal sticks ,making it seem the calipers are bad,
if you need pedal cluster rebuild and or calipers Eric's the guy |
| Jeff73 |
Jul 3 2006, 09:27 PM
The brake pedal is stuck all the way out and will not budge an inch. Clutch and gas pedal work ok. So Eric's the guy eh.
Lo-Fi Version | Time is now: 16th January 2026 - 02:33 AM |
