MEGASQUIRT!, Need some info plz. |
yarin |
Jul 19 2006, 09:09 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I've come to the same conclusion as well..my Innovate wide band is sitting on the desk at home waiting for the install. Now if I can just find some dyno time someplace.... Personally I don't see a need for dyno time. Plug in your desired AFR value into the table, click autotune and let it tune the VE for you. Datalog and view your results. Simple as that. The only thing a dyno would give you is hp/tq figures. I would get it tuned first on the street, then if desired stick it on a dyno for the last 5%. Of course if you are putting out 600+whp then it would be difficult to datalog a pull run on the street, not to mention illegal. I certainly don't have that problem (IMG:style_emoticons/default/biggrin.gif) |
DNHunt |
Jul 19 2006, 09:53 AM
QUOTE Personally I don't see a need for dyno time. Yarin, I really disagree with that statement. Tuning with a wideband allows you to shoot for a target air fuel ratio. No doubt A/F ratio corrolates with engine performance but it supposes 3 assumptions. First, that your WBO2 sensor is acurate, second that the variables ( reporting delay, tuning algorythm, closed loop corrections) in the tuning are minimal or correct, and third and most important, that the arbitrary A/F ratio you pick is the best for the performance you desire. These are big assumptions and the only measure you have on the road is how your butt interprets the results. The dyno gives you a reliable quantitative measure of how effective your tuning is. Do your best but, I would place a bet that a good tuner with a dyno can wring more performance out of your system. Dave |
yarin |
Jul 19 2006, 11:27 AM
QUOTE Personally I don't see a need for dyno time. Yarin, I really disagree with that statement. Tuning with a wideband allows you to shoot for a target air fuel ratio. No doubt A/F ratio corrolates with engine performance but it supposes 3 assumptions. First, that your WBO2 sensor is acurate, second that the variables ( reporting delay, tuning algorythm, closed loop corrections) in the tuning are minimal or correct, and third and most important, that the arbitrary A/F ratio you pick is the best for the performance you desire. These are big assumptions and the only measure you have on the road is how your butt interprets the results. The dyno gives you a reliable quantitative measure of how effective your tuning is. Do your best but, I would place a bet that a good tuner with a dyno can wring more performance out of your system. Dave Dave, Fair statement. Depends on how far the user wants to go. Innovative's WBO2 sensors have been foudn to be dead accurate when compared to those used on a dyno. Either system will report incorrectly if there is an airleak upstream of the sensor. There are many assumptions which define successful self-tuning. My goal was to get the engine "Safely" tuned, then move onto tuning for power. A good tuner can definitely get more out of any standalone engine management system due to the inherant concept that you are tuning for optimum power as supported by a safe AFR. |
JPB |
Jul 19 2006, 02:36 PM
Cool info fellows. I guess a good harness and it could be done for 1K right?
Lo-Fi Version | Time is now: 7th June 2024 - 04:36 PM |
