New brake discs |
New brake discs |
heifetz |
Jul 4 2006, 09:30 AM
Newbie Group: Members Posts: 17 Joined: 3-April 06 From: Scotch Plains, NJ Member No.: 5,812 |
Just got a new pair of rear brake discs from PP. They are painted gray on the non-brake surfaces. Can I leave the paint on? Also, there is a film of oil on the brake surfaces. I'll clean that with brake cleaner. Anything else I need to do to the the discs before I put them on the car?
DanT |
Jul 4 2006, 10:05 AM
Just got a new pair of rear brake discs from PP. They are painted gray on the non-brake surfaces. Can I leave the paint on? Also, there is a film of oil on the brake surfaces. I'll clean that with brake cleaner. Anything else I need to do to the the discs before I put them on the car? Leave the paint alone....it will keep the non braking surface from rusting. (IMG:style_emoticons/default/smile.gif) Just clean the braking surface with brake cleaner and install as normal. Enjoy new rotors....are you installing new pads also...you should be. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:47 PM |
