Electrical grimlin |
lmcchesney |
Jul 4 2006, 04:33 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
Well, now that the 914 is running, the electrical grimlin decided to jump aboard.
When ideling, 1200 rpm, the red alternator light comes on faintly, the fuel level sender drops to reserve, the turn signals stop working and even the tach. drops to zero. (IMG:style_emoticons/default/WTF.gif) I checked the relays on the board and reviewed the fuses. Ideas (IMG:style_emoticons/default/blink.gif) Thanks, Larry |
krazykonrad |
Jul 4 2006, 06:35 PM
Senior Member Group: Members Posts: 1,126 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Stat checking your grounds all around including the straps. Also it could be your alternator itself. I have no idea if this is the source of the problem, but its a good place to start. Best of luck!
Konrad |
So.Cal.914 |
Jul 4 2006, 07:23 PM
A few years ago I was having all sorts of problems. Not that things didn't work but
things were acting very funny ( not ha ha funny). So I cleaned all of the grounds and pulled the fuse block down, marked all of the wires with numbers on tape and drew a diagram of the block so it would be easy to hook the wires up after. I used a liquid metal cleaner and cleaned the hell out of the fuse block. I put it back in and low and behold everything worked like new. Best hour I had spent on the teener in years. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:51 AM |
