Rain Tray Funnels and Drain Tubes |
AvalonFal |
Jul 4 2006, 05:05 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
I'm curious what is the proper way for the rain tray funnels to be connected to the drain tubes?? Are they simply pushed on?? Glued?? Hose clamped?? My '74 has pull ties holding the tubes onto the funnels (from PO) & that doesn't seem right.
Also, what is the proper color of the tubes? Mine are clear & all I've seen on other 914's have been black. A re-do by the PO also, perhaps? |
Pat Garvey |
Jul 4 2006, 07:30 PM
I'm curious what is the proper way for the rain tray funnels to be connected to the drain tubes?? Are they simply pushed on?? Glued?? Hose clamped?? My '74 has pull ties holding the tubes onto the funnels (from PO) & that doesn't seem right. Also, what is the proper color of the tubes? Mine are clear & all I've seen on other 914's have been black. A re-do by the PO also, perhaps? Check my pic - from my 72. Clear tubes - no. Pull ties - don't think so, but it's not a bad idea. If it works & you're not a CW, keep it. Actually sounds like a decent idea. Just not factory. Attached thumbnail(s) |
AvalonFal |
Jul 4 2006, 07:36 PM
Thanks, Pat. A picture IS worth a 1000 words!! You've cleared up my confusion.
Pat Garvey |
Jul 6 2006, 06:04 PM
914rrr |
Jul 13 2006, 03:42 PM
Senior Member Group: Members Posts: 1,821 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
A good source for drain tubes is VW Super Beetles. They use the exact same material for the fresh air drain tubes in the front trunk and the tubes are longer. The only difference is a 'molded' end section to make it easier to put on. Best part is, most of the ones you'll find are in great shape, as they are out of the sun and not exposed to heat like the teeners are.
Pat Garvey |
Jul 13 2006, 06:01 PM
Thanks, Pat. A picture IS worth a 1000 words!! You've cleared up my confusion. I just bought a set from Evilbay - think I paid $3.75 for them. If you want them, let me know - $3.75 & ship costs. Don't even kno why I bought them, except they were cheap. Yous if you want them. Pat |
Lo-Fi Version | Time is now: 27th April 2024 - 04:02 AM |
