Another dumb question?, logo in or logo out?? |
East coaster |
Jul 6 2006, 09:38 PM
Senior Member Group: Members Posts: 1,672 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
I'm installing my rear window tomorrow and since I already completely cleaned all the tape/residue from the window, there's no longer any tell tale signs of which side was inside and which was out! The only way to distinguish one side from the other is the v-dub logo/text on one side.
Does the little V-dub logo go on the inside or out?? I realize it probably doesn't matter, but I'd rather put it back the way it supposed to be. |
Mike McGrath |
Jul 6 2006, 10:01 PM
Member Group: Members Posts: 98 Joined: 5-December 04 From: Portland, Oregon Member No.: 3,225 |
I'm installing my rear window tomorrow and since I already completely cleaned all the tape/residue from the window, there's no longer any tell tale signs of which side was inside and which was out! The only way to distinguish one side from the other is the v-dub logo/text on one side. Does the little V-dub logo go on the inside or out?? I realize it probably doesn't matter, but I'd rather put it back the way it supposed to be. Someone once told me that it did matter and you were supposed to put it back in the same side in and out. Are you sure you cleaned it that well??? Maybe there's a little left. I'd try it both ways to make sure, just in case. Mike (in Portland) |
So.Cal.914 |
Jul 6 2006, 10:09 PM
I haven't done much auto glass, but I have worked as a glazer. When we would
set glass we would put the bug on the inside at the bottem |
jonwatts |
Jul 6 2006, 11:12 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
If you breath on the glass (fog it up) near the edge you may be able to tell which side had the seal and which didn't.
Lo-Fi Version | Time is now: 15th May 2024 - 09:06 PM |
