#269 Rust - Is it too far gone? |
mr914 |
Oct 10 2003, 02:08 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
2013 note...
Lesson 1- before attempting this at home, get the alignment checked on a frame machine. I built custom door/chassis reinforcement bars before going on the rotisserie. Assuming that the PO had repaired the longitudinals correctly. After 12 years, the car finally landed on the jack stands. As the original Dorris were thoroughly rusted out, I had replacement doors. Bolted the replacement doors on, and the don't fit. Bolted original doors on and they do with funky gaps.... Put the reinforcement bars on and the fit like I had built them.. (IMG:style_emoticons/default/huh.gif) looked at how the front strut upper plates were located. One has never moved based on factory tar, the other one had been moved 1/4-3/8" Damn, why didn't I catch that years ago... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Did test assemble, top, doors gaskets. Car is square but the longs appear to be bowed, fortunately evenly. Put the reinforcement bars on and they fit like I had built them.. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Based on the targa top fitment, it Looks like the car is bowed 1/8-3/16". With the replacement doors, the front gap is good and even, the rear is 3/8" high at the body line (stack of 5 US Quarters). Hung the original doors, drivers door is spot on, rusted at the bottom and evidence of a cut and re weld between the hinges. Damn-it, unbolted the doors, put them on the shelf in the basement and ignored them for 10+ years About .040 in shims and the new doors are on and the gap varies by about 1/8" More of that story, at the end of the post Back to the original post... Well, I have the car mostly stripped and up on a rotiserie. When I got the car I saw the rust on the Sail panel, cowl, edges of the rear fenders and 2 small holes in the floor board. Now that I have stripped it, It's much worse. It's a '70 914-6 #269 What do you think? CAUTION: SCROLLING DOWN MAY MAKE YOU SICK (IMG:style_emoticons/default/barf.gif) or DRINK HEAVILY (IMG:style_emoticons/default/beer3.gif) Attached image(s) |
mr914 |
Oct 10 2003, 02:09 PM
Under the gas tank
mr914 |
Oct 10 2003, 02:10 PM
More under the fuel tank
mr914 |
Oct 10 2003, 02:12 PM
What's left on the pass side to attach the floor pan to... view 1
Brad Roberts |
I think its a 9146 and some good 4cyl sheet metal should be utilized for the repairs.
It appears your semi setup to take this on.. jump in. B |
mr914 |
Oct 10 2003, 02:13 PM
What's left on the pass side to attach the floor pan to... view 2
mr914 |
What's left on the pass side to attach the floor pan to... view 3
mr914 |
What's left on the pass side to attach the floor pan to... view 4
mr914 |
Oct 10 2003, 02:14 PM
What's left on the pass side to attach the floor pan to... view 5
Bleyseng |
Oct 10 2003, 02:15 PM
Doesn't look that bad too me for a six. How are the longs?
Geoff |
mr914 |
Inside front fender 1
mr914 |
Lower portion of front inner fender
mr914 |
Oct 10 2003, 02:16 PM
Battery box area
mr914 |
Oct 10 2003, 02:17 PM
More battery box
Brad Roberts |
Oct 10 2003, 02:18 PM
I think you 'really' have to love the 914's to tackle this project. But I have seen worse..
I have another 9146 tub down the street from me for 1000$ (complete roller) that is a tad better than this one. The floorpans are more solid. B |
Brad Roberts |
Oct 10 2003, 02:19 PM
Damn.. the one area that is solid.
This is a salt infested northern car... no doubt about it. Sat in a field with snow after being driven for years in the ice and snow. B |
mr914 |
Oct 10 2003, 02:20 PM
I've got most of the parts and some cutouts from donor 4's.
The kicker is the area between (and including) the master cylinder mount to the passenger foot well. Everything I've looked at for donors is trashed there. |
mr914 |
Oct 10 2003, 02:22 PM
First time I've ever seen rust in the cowl area.
The longitudinals are basicly sold. Someone else did a good job of stiching in some repairs. There is some portions of the lower longitudinals that are crappy. Attached image(s) |
Brad Roberts |
Not in this state.
Matter of fact.. I think I still have Jenny's left over from her wreck. It might still be good. Just dont ask me to ship it this year. I cant get the parts out that I have already cut. B |
mr914 |
Oct 10 2003, 02:25 PM
This year????
I'm in Michigan, This is probbably the last weekend to do much before it's time to put on the parka..... I think I'll blast some more undercoating off and primer seal the car for the winter. BTW: I made my own rotiserie |
Lo-Fi Version | Time is now: 17th May 2024 - 11:13 PM |
