#269 Rust - Is it too far gone? |
mr914 |
Oct 10 2003, 02:30 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I agree with the salt.
It appears that the car was zbarted in the early 70's after it started to rust. I'm convinced most of the floor pan rust was becuase the PO had the wrong size tires on, causing the undercoating to be rubbed off of the inner fenderwell. Then being hidden by the foam block. The rust did its thing. Some off the local 914 guys have known of this car for years. One suggested that most of the problem was because the car sat in a unheated garage on concrete for years. Needless to say, it's a complete Rust-or-ation. More photos to come |
morgan |
Oct 10 2003, 03:29 PM
Member Group: Members Posts: 310 Joined: 28-March 03 From: milwaukee WI Member No.: 488 |
Why not just retub it. you can find a good tub that is the same year. there just a few things that are diferent from a 4
John (IMG:style_emoticons/default/chatsmiley.gif) |
Brad Roberts |
Oct 10 2003, 03:32 PM
Are you and George Hussey related ??
Ranks right up there with all the DZ302 Z28's that where never built from the factory. B |
morgan |
Oct 10 2003, 03:36 PM
On second thought, buy brads. You will save so much time and money!!!!!!!!!!!!!!!!!!!!!!!!!!!
I bought a tub from la la land to redo my 916/6 It got hit hard in the front. It was just better to start with a better tub John |
Brad Roberts |
Oct 10 2003, 03:41 PM
I just see a lot of "crap" floating around when it comes to these cars. Anything I can do to stop it now and in the future.. I will.
I'm not a fan of swapping VIN's.. can you tell ?? (IMG:style_emoticons/default/laugh.gif) B |
morgan |
Oct 10 2003, 03:55 PM
Retubbing a car is ONLY OK if you tell people you did that.
I have seen to many asshole out there Lie cheat about there cars. When my car is done There will be a book of pictures to go with it. John |
mr914 |
Oct 10 2003, 06:52 PM
But if I re tub it. It would not be original.
The major problem is in the front floor pan area to under the gas tank. The sail panel on the pass side won't be that bad. Or at least much less of a nightmare than the front part. Both trunks are in great shape! The other option is to drop the 6 into my '71 4cyl and ignore the 6 carcass for a couple of years. The 71 already has the stiffening kit, M struts etc etc etc.... |
ChrisFoley |
Oct 11 2003, 05:01 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've repaired all of those areas with new sheetmetal before (except for an entire floor), but a donor car would make it go quicker.
Definitely worth saving IMO. |
Lotus914 |
Oct 11 2003, 08:06 PM
Newbie Group: Members Posts: 38 Joined: 10-October 03 From: bleak suburbia Member No.: 1,234 |
Mike Galloway (Mike's 914's) may have some donor sheet metal or could do a top-notch job of the welding over the winter, and would charge you Canadian funds. Get a primed tub back in the spring! He's near Toronto 905-922-8987.
Dave |
914werke |
Oct 11 2003, 09:04 PM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Um ..I guess the questions are: what is more importent, that it is "Original" (IMG:style_emoticons/default/blink.gif) ,
or that your wallet has not been pillaged and you can DRIVE your teener (IMG:style_emoticons/default/smash.gif) |
Mark Henry |
Oct 12 2003, 06:17 AM
QUOTE(Lotus914 @ Oct 11 2003, 06:06 PM) Mike Galloway (Mike's 914's) may have some donor sheet metal or could do a top-notch job of the welding over the winter, and would charge you Canadian funds. Get a primed tub back in the spring! He's near Toronto 905-922-8987. Dave I second that... For someone in the northeast, who may want work done, Mike is a great guy. With the Canadian dollar you will be paying around .60 cents on the US dollar. But he would make a deal on the total (or part) job that you want done. He hasn't updated his web page in ages but here it is. http://members.tripod.com/mike4g/ |
mr914 |
Oct 13 2003, 02:03 PM
Thanks for the input.
I'll have to check with Mike as Toronto is only a couple of hours from here (once you get thru the border). As far as driving, I already have a teener and an eleven, so I'm not without the Porsche Driving Experience. Love indian summer, Drove the 911 to work today. I have some of the donor parts already. It's just the middle section that surprised me. |
mr914 |
Oct 13 2003, 02:05 PM
I noticed something different last night.
My 914-6 has two rubber grommets for the fuel lines to go thru. While my '71 4cyl has a rubber block. Anyone know when the factory changed to the other style? |
ChrisFoley |
Oct 13 2003, 05:07 PM
My parts catalog doesn't even list the two grommet style. The single grommet is listed for all models.
Rusty |
Oct 13 2003, 06:12 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
My /6 has two grommets, too. The only reason I noticed it is because I changed out the fuel lines. Never thought about it before you mentioned it.
-Rusty (IMG:style_emoticons/default/smoke.gif) |
mr914 |
Oct 13 2003, 08:16 PM
Mine is basicly gone.
I'm thinking about making a box to use bulkhead fittings -6 for braided lines for a replacement. Attached image(s) |
mr914 |
Oct 13 2003, 08:20 PM
Front trunk is good
mr914 |
Oct 13 2003, 08:21 PM
Except under one headlight bucket
mr914 |
Oct 13 2003, 08:23 PM
How close do you park your Porsches in your garage? (IMG:style_emoticons/default/blink.gif)
Dial up sucks! (IMG:style_emoticons/default/barf.gif) Rather use the T1 at work (IMG:style_emoticons/default/aktion035.gif) Attached image(s) |
mr914 |
Oct 13 2003, 08:28 PM
No, I did not scratch either. Pulled mirror out for effect. (IMG:style_emoticons/default/blink.gif)
Normally part 2-3 inches apart (IMG:style_emoticons/default/smile.gif) Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 10:04 PM |
