75-76 front fuel pump conversion 1/2" fuel line? Help, I am trying to hook up a 75 fuel pump in my 73 but the lines dont make |
VintageExcellence |
Jul 8 2006, 05:25 PM
Member Group: Members Posts: 52 Joined: 27-August 04 From: San Diego, CA Member No.: 2,636 |
So I am installing a 75 fule pump into my 73 914-6 conversion. I have a rebuilt 75 fuel pump, and a Motronic fuel pump from the 86 911 I got my engine from.
The inlet side nipple of both fuel pumps is just a hair under 1/2". Now I have not seen a fulr tank nipple that is also 1/2" nor have I seen any fuel line that is close to 1/2" ID. Am I missing something? What is going on, why is there such a large fuel line nipple on these fuel pumps? Can anyone help me, I can't believe this is holding me up on getting my 914-6 conversion going. Thanks |
Kirmizi |
Jul 8 2006, 06:15 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
For what it's worth, I just replaced the front fuel lines and pump in my '75 carb'd 4 cylinder. The new pump was for a /6 and both inlet and outlet fit the new 5/16" (7.9mm) hose. Previously, there were two fuel filters installed (and two pumps, go figure). One of the filters had what looked to be a 5/16" inlet but an approx. 3/8" outlet; P/N 0.450.901.005. The other filter had the same size inlet/outlet; 0.450.901.003. Hope this helps. Mike
VintageExcellence |
Jul 8 2006, 06:46 PM
For what it's worth, I just replaced the front fuel lines and pump in my '75 carb'd 4 cylinder. The new pump was for a /6 and both inlet and outlet fit the new 5/16" (7.9mm) hose. Previously, there were two fuel filters installed (and two pumps, go figure). One of the filters had what looked to be a 5/16" inlet but an approx. 3/8" outlet; P/N 0.450.901.005. The other filter had the same size inlet/outlet; 0.450.901.003. Hope this helps. Mike Thanks, so you are saying you used a 914-6 fuel pump? I have a 914-6 stitting in my yard awaiting restoration. Maybe I can pull the pump and try it. I need a electric fuel pump that has 5/16 inlet and outlet, that would be perfect. I can't use the early 4cyl 3 nipple pump because my lines are not routed for that pump. These conversions can be tricky when using Motronic FI, my carbed 3.0L was much easier. |
mihai914 |
Jul 8 2006, 07:22 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
I think that what you are missing is a 75-76 fuel filter which will have a small inlet and bigger outlet. That should fix your problem. I doubt you can use the -6 pump since it's application is carbs and yours is FI. If I were you, I would use the pump that came with the engine, provided that it works well. The 914 pump will work also if it can provide enough flow for the 3.0.
eeyore |
Jul 8 2006, 08:41 PM
Lo-Fi Version | Time is now: 14th May 2024 - 06:44 AM |
