bouncing speedo |
bouncing speedo |
terrymason |
Jul 10 2006, 07:48 AM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
Just got a new 914, and the speedo bounces all over the place. The previous owner said he replaced it, and the replacement started doing the same thing a few days later. Any idea what would cause this?
mihai914 |
Jul 10 2006, 07:51 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
You should check the condition of the speedo cable, sometimes they pass too close to the engine and kind of get cooked. Not too bad to replace if it's the culprit.
terrymason |
Jul 10 2006, 08:34 AM
Thanks!
It sounds like like I will need to take the dash out, and pull the speedo to change the cable. I will try swapping it with the one in my 71 |
Jul 10 2006, 08:41 AM
hi,
no need to remove the dash. the guage will pop out if you push it from the back. Rich |
ptravnic |
Jul 10 2006, 09:50 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Your speedo cable is kinked somewhere - I'm guessing your speedo bounces alot (wide range of readings) and at high speeds kinda settles down (smaller range of readings).
Ask me how I know... |
Lo-Fi Version | Time is now: 15th May 2024 - 01:43 AM |
