terrymason
Jul 10 2006, 07:48 AM
Just got a new 914, and the speedo bounces all over the place. The previous owner said he replaced it, and the replacement started doing the same thing a few days later. Any idea what would cause this?
mihai914
Jul 10 2006, 07:51 AM
You should check the condition of the speedo cable, sometimes they pass too close to the engine and kind of get cooked. Not too bad to replace if it's the culprit.
terrymason
Jul 10 2006, 08:34 AM
Thanks!
It sounds like like I will need to take the dash out, and pull the speedo to change the cable. I will try swapping it with the one in my 71
r_towle
Jul 10 2006, 08:41 AM
hi,
no need to remove the dash.
the guage will pop out if you push it from the back.
Rich
ptravnic
Jul 10 2006, 09:50 AM
Your speedo cable is kinked somewhere - I'm guessing your speedo bounces alot (wide range of readings) and at high speeds kinda settles down (smaller range of readings).
Ask me how I know...
