battery mount in race car |
vintage914racer |
Jul 10 2006, 03:42 PM
Member Group: Members Posts: 429 Joined: 28-December 03 From: Minneapolis, MN Member No.: 1,473 |
As I read the fineprint on the race car tech info sheet for SVRA I have found that they require a "metal hold down device." For years I have used a marine battery box that is bolted down and as an extra precaution strapped to the cross member in my trunk. While it has worked great, I am not sure it will pass tech based on their wording.
So I am looking for suggestions on what to do. I don't really want to ditch the marine box, due to potential leakage, and was thinking of jury rigging a metal cross bar across the top. Unfortunately it will have to be rather basic since I am not the best fabricator. My goal is not to drill a bunch of wholes in the car. To make matters worse I need to make it tonight or tomorrow as I leave town Wed AM. Any suggestions would be appreciated. |
lapuwali |
Jul 10 2006, 04:44 PM
One piece of angle across the top of the box, and two long bolts through holes drilled in the end. Minimal fabrication required.
Crazyhippy |
Jul 11 2006, 10:47 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
I've seen dirt oval cars running long hose clamps around the battery and pass tech no problem.
Depends on the exact rule mostly. BJH |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:10 AM |
