Dizzy Woes!, almost on the road.... |
wertygrog |
Jul 13 2006, 10:07 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
Hello, I've been trying to work the bugs out of my 2.0L w/ dual 40mm webers, and to start off I want to check/adjust dwell and timing. I just discovered today that my car has the junky 009 dizzy....I also have the bosch blue coil and new plugs/wires.
Do I go about timing this dizzy the same way as a stock dizzy (minus the vacuum lines of course) AKA 27 degrees @ 3500rpm, or is this not possible because I have a 009? Also, is 27 degrees BTDC preferred even with carbs, or should I go to 34 or something? Next quesiton: I am sorely aware of the mediocrity of the 009, so what are my inexpensive options for a better centrifugal advance dizzy, and where can they be bought? (IMG:style_emoticons/default/smile.gif) thanks a bunch! |
Lo-Fi Version | Time is now: 17th May 2024 - 03:58 AM |
