Carb air cleaners |
Carb air cleaners |
MJHanna |
Oct 13 2003, 11:36 AM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
If your going to run carbs then run some air cleaners that will let them breath. (IMG:style_emoticons/default/boldblue.gif)
URY914 |
Oct 13 2003, 11:39 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Is that a Mallory dizzy?
Paul |
MJHanna |
Oct 13 2003, 03:23 PM
Nope MSD , plugs into a 6AL with part of a 911 wire set for wires.
Lotus914 |
Oct 13 2003, 08:47 PM
Newbie Group: Members Posts: 38 Joined: 10-October 03 From: bleak suburbia Member No.: 1,234 |
Those is BIG! No rain tray on that car!
Dave |
Aaron Cox |
Oct 13 2003, 08:55 PM
does anyone make watershields for /4's?
mharrison |
Oct 13 2003, 09:26 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
Is the front wall of the trunk cut so those air cleaners will fit, or cut for something else?
MJHanna |
Oct 14 2003, 02:57 PM
QUOTE(mharrison @ Oct 13 2003, 09:26 PM) Is the front wall of the trunk cut so those air cleaners will fit, or cut for something else? Cut for easy access to adjust carbs , linkage not for the air cleaners. I dont worry about water with this car can you tell (IMG:style_emoticons/default/laugh.gif) Attached image(s) |
Brad Roberts |
Oct 15 2003, 01:25 AM
Oberg oil filter... cool.
Yep. I like the tall stacks with tall air cleaners. Why the 911 wire set Mark ?? What have you found ?? B |
maf914 |
Oct 15 2003, 07:19 AM
What type hose and fittings are you using for your oil lines? They look like commercial type hydraulic lines with crimped fittings.
Thanks, Mike |
rhodyguy |
Oct 15 2003, 07:20 AM
is that a hot start relay mounted in the trunk too?
kevin |
MJHanna |
Oct 15 2003, 07:45 AM
QUOTE(Brad Roberts @ Oct 15 2003, 01:25 AM) Oberg oil filter... cool. Yep. I like the tall stacks with tall air cleaners. Why the 911 wire set Mark ?? What have you found ?? B Paranoid is the reason for the Oberg tattle tail filter. I have run MSD wires for years as the MSD 6 AL really likes them and they plug into to the MSD dizzy but they suck at the plug end. You have to cut the rubber down and they give a poor seal. The 911 wires just happen to have the same connection as the MSD dizzy with better end for sealing and attachment to the spark plug. The MSD signal likes them. The hose are all Aeroquip with the “press on” end fittings I have used them for years. You have to cut the ends off the hose if you want to get them off. This hose is the same hose that Aeroquip uses on the Steel braided hose, just less expensive and easier to get. Your right, you can go to any hydraulic house and get it. |
MJHanna |
Oct 15 2003, 07:46 AM
QUOTE(rhodyguy @ Oct 15 2003, 07:20 AM) is that a hot start relay mounted in the trunk too? kevin Yes, it got moved, to keep it out of the way and to "Clean it up". (IMG:style_emoticons/default/laugh.gif) |
MJHanna |
Oct 15 2003, 07:49 AM
you can see the fittings a little better
MJHanna |
Oct 15 2003, 07:51 AM
heres the hot start
Lo-Fi Version | Time is now: 17th May 2024 - 02:39 PM |
