QUOTE(Brad Roberts @ Oct 15 2003, 01:25 AM)
Oberg oil filter... cool.
Yep. I like the tall stacks with tall air cleaners.
Why the 911 wire set Mark ?? What have you found ??
B
Paranoid is the reason for the Oberg tattle tail filter. I have run MSD wires for years as the MSD 6 AL really likes them and they plug into to the MSD dizzy but they suck at the plug end. You have to cut the rubber down and they give a poor seal. The 911 wires just happen to have the same connection as the MSD dizzy with better end for sealing and attachment to the spark plug. The MSD signal likes them.
The hose are all Aeroquip with the “press on” end fittings I have used them for years. You have to cut the ends off the hose if you want to get them off. This hose is the same hose that Aeroquip uses on the Steel braided hose, just less expensive and easier to get. Your right, you can go to any hydraulic house and get it.
