keeps dying on deceleration, what is wrong with my teener NOW!? |
sk8kat1 |
Jul 17 2006, 09:50 AM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
(IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif)
ok she runs pretty sooth now .. but I have some cocerns -- I think it runs a bit on the hot side ( see other post ) , it burns quite a bit of oil ... or might be pissing from a leak under load, after I cahnged the oil it was pretty much black after a coulpe of drives .... when I come to a stop suddenly it drops RPMs but then recovers .. as I drive it more and the car starts to get what I think maybe on the overly hot side it doesn't recover as easily and the rpm's drop , the oil light comes on and some times the car dies ... this usually occours when coming to a stop .. it drops a bit then as aI sit at the light it starts to die .. or sometimes I am fine the it just starts to drop RPMs and the oil light comes on and it starts to die out ... I found a big vacum leak in the elbow that goes in just below the throttle body -- I couldn't find a replacement so as a temp fix -- 80 MPH duct tape ... I know a DAPO move but I needed to see if that corrected some of my issues -- It did correct alot of things .. but this issue remains info on the car : 1973 2.0L stock FI PO says the engine was rebuilt about 500 mile before I got it (IMG:style_emoticons/default/confused24.gif) |
sk8kat1 |
Jul 17 2006, 01:03 PM
sk8kat1 |
Jul 18 2006, 03:42 PM
(IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif)
please .. any ideas ... decel valve ... manifold pressure sensor.... a vacum leak that is hiding... |
Rand |
Jul 18 2006, 04:01 PM
I wouldn't think a vacuum leak because that typically causes fast idle with DJet.
Are you certain the timing is on? |
sk8kat1 |
Jul 18 2006, 04:02 PM
not for a fact .. but it only really happens as the the car is run for a while .. and get hot
Jul 18 2006, 04:22 PM
so, the motor was rebuilt 500 miles ago..
you need to look really close at the oil. drain it into a clean pan..see if there is metal in there. Find out what rebuilt means. who did it,,,talk to the mechanic...etc... As far as stalling when hot...check your timing..you could be to far advanced..but that will also make it har to start when hot.. check your fresh air flappers, and make sure they are hooked up correctly.. I would suggest that you look up Brad in Peoria, he has a 914 shop there. Spend the time and money and have him give you a good once over on the car..you dont want to burn up the motor. Rich |
Air_Cooled_Nut |
Jul 18 2006, 06:00 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
...PO says the engine was rebuilt about 500 mile before I got it ... How many times have we heard that before? (IMG:style_emoticons/default/dry.gif) |
rcrgrl |
Jul 18 2006, 08:10 PM
Member Group: Members Posts: 202 Joined: 19-April 06 From: San Diego, CA Member No.: 5,893 |
mine's doing the same thing - except it doesn't always respond to throttle to bring the rpm's back up. i;m gonna look at timing tonight, but if you come up with anything else, post it for us interested folks!
jimkelly |
Jul 18 2006, 08:23 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
mine was acting weird after it got hot - after 15 minutes of driving - turned out to be a dying condensor.
Lo-Fi Version | Time is now: 17th May 2024 - 06:14 PM |
