Headlight pushrod snapped, First time I've had THIS part break |
RoadGlue |
Jul 17 2006, 01:03 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
I had a first yesterday when the headlight pushrod (at least that's what I think it's called) snapped. Sylvie and I had just taken a nice ride out from Sebastopol to the ocean and I had been using the headlights. Stopped at my dad's place, hopped back into the car, hit the headlight switch and only the right-side light popped up. Doh!
I have a bracket I can pull of my other 914. Is this going to be a PIA to replace? Should I prepare to replace any other headlight assembly parts while I'm in there? Here are the pics: (IMG:http://www.sonic.net/randyw/914club/headlight1.jpg) (IMG:http://www.sonic.net/randyw/914club/headlight2.jpg) (IMG:http://www.sonic.net/randyw/914club/headlight3.jpg) Thanks! |
Crazyhippy |
Jul 17 2006, 01:08 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
It's fairly easy to replace. Mine broke and FUBAR'd the paint wheen the light still went up.....
3 allen bolts from inside the front trunk and you're good to go. BJH |
Crazyhippy |
Jul 17 2006, 01:09 PM
oh yeah, check the other side too... they've been through the same amount of work cycles.
RoadGlue |
Jul 17 2006, 01:14 PM
racerx9146 |
Jul 17 2006, 01:34 PM
good design never goes out of date.. Group: Members Posts: 174 Joined: 1-January 04 From: Sacramento, CA Member No.: 1,483 Region Association: Northern California |
Hey Randy
Long time no hear, John from Sacramento here, dont forget to lube and clean the pivot bushings, there is a reason the bracker broke (IMG:style_emoticons/default/smile.gif) oh yeah, check the other side too... they've been through the same amount of work cycles. Good idea! |
RoadGlue |
Jul 17 2006, 01:36 PM
Hey Randy Long time no hear, John from Sacramento here, dont forget to lube and clean the pivot bushings, there is a reason the bracker broke (IMG:style_emoticons/default/smile.gif) Hi John! Thanks for the tip. Don't cook to death today, k? The morning news said that it's going to be around 107* today in Sac! |
racerx9146 |
Jul 17 2006, 01:43 PM
no kidding, its friggen hot here today! sometimes i wonder why i ever left the bay area... at least my daily driver (323 GTX) has a/c, sort of, you have to turn off the A/C if traffic slows down, cooling system can't keep up. Why can i just buy a normal car?
RoadGlue |
Jul 17 2006, 01:54 PM
no kidding, its friggen hot here today! sometimes i wonder why i ever left the bay area... at least my daily driver (323 GTX) has a/c, sort of, you have to turn off the A/C if traffic slows down, cooling system can't keep up. Why can i just buy a normal car? The 323 GTX is a very cool car! Talk about a sleeper too. Always wanted one to go through the SCCA Rally school with. |
Jul 17 2006, 03:26 PM
Don't forget--there are inboard and outboard pivots on each headlight. I think the outboard is held on by three Allen-head bolts, and the inboard by two. (Or I could have that swapped.) The outboard ones, since they are in the fender well, are a PITA to loosen. Clean the heck out of the area, and hose the bolts down with penetrating oil. (WD-40 is not a penetrating oil!)
--DD |
RoadGlue |
Jul 18 2006, 07:29 PM
Don't forget--there are inboard and outboard pivots on each headlight. I think the outboard is held on by three Allen-head bolts, and the inboard by two. (Or I could have that swapped.) The outboard ones, since they are in the fender well, are a PITA to loosen. Clean the heck out of the area, and hose the bolts down with penetrating oil. (WD-40 is not a penetrating oil!) --DD The inboard bolts were't a problem on either of my 914s (parts car, driver) when I fixed this problem this morning. It's mostly fixed (see below), yay! However, the headlight now sits about a 1/2 too low when turned off (much like the first photo in this thread). Perhaps I bent something, though I really dug around and couldn't see what might have bent. I wonder if perhaps the lever arm (next to the headlight relay) could have slipped where it attaches to the motor. There's a 10mm nut there, so perhaps I'll head out there now that it's cooling off and see if I can adjust that. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:55 PM |
