Antidive, how to adjust it... |
Mike T |
Jul 17 2006, 06:29 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
I am somewhat familiar with antidive characteristics with a double a-arm type suspension but was surprised today when I read on the Pelican board a discussion of increasing antidive on a 911 front suspension(similar to our 914) by shimming the front torsion bar mount down.
Has anyone played with that at all? What was your result? How much of a shim would be needed? Mike T |
groot |
Jul 18 2006, 06:46 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
The benefits are certainly debatable. The downside is impact harshness and the inability for the suspension to keep the tire on the ground when facing a sharp bump (transition to concrete for example).
Mike T |
Jul 18 2006, 07:36 AM
The benefits are certainly debatable. The downside is impact harshness and the inability for the suspension to keep the tire on the ground when facing a sharp bump (transition to concrete for example). Maybe that's why Staniforth says it goes in and out of fashion in the racing world. There are tradeoffs. I have a V8 autocross car and I am fighting rear end looseness on hard braking. When I stop with the steering dead straight there is no problem but add any steering input and the rear tends to want to slew around. I have adjusted rear Koni firmness and it seems to help with a firmer setting but then in transitions such as a high speed slalom the back gets looser. The front bites well with no understeer. This week I am evaluating the car. Alignment settings, bushing condition, etc. Car Specs; weight 2215 with driver 58% weight on rear 52% weight on drivers side Koni reds front and rear 250lb rear springs 22mm torsion bars 22mm Welt front swaybar set about 1/2 no rear swaybar -1° camber front 3/16" toe out front ?° camber rear 0 toe rear 23.5x12-15 Hoosier R25a rear on 14" wide wheels 22.5x9-15 Hoosier R25a front on 10" wheels Weltmeister Polygraphite bushings front and rear(8 years old) camberball upper strut mounts turbo tie rods welt bumpsteer spacers lowered with front control arms and rear semi trailing arms parallel to ground Mike T |
Lo-Fi Version | Time is now: 20th May 2024 - 12:17 PM |
