| CoolAirVw |
Nov 26 2006, 04:20 PM
Member ![]() ![]() Group: Members Posts: 66 Joined: 4-July 06 From: Kansas City Area Missouri Member No.: 6,370 |
Blocked off EGR Discussed at this link.
Tried to put the steering column back in but there is a bushing broken. I think I found it a Pelican. Ignition switch has a crack in it but it seems to work. I'll order a new one of those also. After getting screwed by the locksmith I found a peice broken in the lock cylinder so I'll need to find one of those. I'm going to use the ignition switch without the lock to try to start for now. Why is it in the process of fixing one thing I find 5 more things that need fixed? |
| majkos |
Nov 26 2006, 06:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
Blocked off EGR Discussed at this link. Tried to put the steering column back in but there is a bushing broken. I think I found it a Pelican. Ignition switch has a crack in it but it seems to work. I'll order a new one of those also. After getting screwed by the locksmith I found a peice broken in the lock cylinder so I'll need to find one of those. I'm going to use the ignition switch without the lock to try to start for now. Why is it in the process of fixing one thing I find 5 more things that need fixed? Errr.........because you bought a Rat infested 914? You KNEW it's going to be a project,Silly! BTW,you're doing just find,keep plugging away, and oh yeah (IMG:style_emoticons/default/welcome.png) |
| SGB |
Nov 26 2006, 08:35 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
| CoolAirVw |
Oct 25 2012, 04:45 AM
I realized I never updated this thread. After a few struggles I reinstalled the engine, and started the car and drove it. All stock fuel injection worked.
Drove the car and tinkered with a few issues. Drove the car home and its been parked eversince. Started a business in the meantime, working on Vw's (mostly diesels) and thats keeping me too busy to work on projects. I probably should sell this car and my 75 bug. |
| FourBlades |
Oct 25 2012, 06:05 AM
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States
Sounds like its a pretty solid car. You should drive it! John |
| Tilly74 |
Oct 25 2012, 08:39 AM
Member ![]() ![]() Group: Members Posts: 96 Joined: 5-June 12 From: Springfield, MO Member No.: 14,522 Region Association: None |
Looks like you've got things under control. I'm in Springfield, so if you ever need a hand, or want to have one of those "914 parties" let me know! I've only seen 2 914's in real life. Mine, and one on the road 6 years ago (IMG:style_emoticons/default/blink.gif) . |
Lo-Fi Version | Time is now: 1st May 2026 - 03:03 PM |
