front hood seal- somethings wrong, teck Q |
arc914 |
Jul 20 2006, 11:39 AM
Member Group: Members Posts: 139 Joined: 9-April 05 From: Sault Ste Marie,on,Canada Member No.: 3,905 |
Ok guru's
Who has bought the aftermarket front hood seal? this question is for you. I did my instal on wed and now my hood barely is able to close. Should i just give it time under pressure to settle or did i make a huge problem with the aftermarket one? andrew in the Soo |
John |
Jul 20 2006, 11:51 AM
Did you glue the seal in?
I don't glue the seals in anymore as I believe that the glue can help to promote rot, and I can pull my seal out and clean the dirt out of the channel when I want to. All the front hood seals that I have used made it hard to close the hood for a some time until the seal "relaxed" enough. Stick with it. |
bd1308 |
Jul 20 2006, 12:10 PM
I have the aftermarket seal. Xmas gift some years back.
It works okay, I did notice some resistance to closing when it was first installed, but it settled down. b |
Dr Evil |
Jul 20 2006, 12:12 PM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I have a new aftermarket one and it resists closing. Also, it would not stay in place with out some adhesive.
arc914 |
Jul 20 2006, 12:21 PM
I glued it down solid all around and i had to stretch it to reach the corners then clamped it till the adhesive dried.
thought this fix would be a no brainer (teener strikes again) cheers |
Chris Pincetich |
Jul 20 2006, 12:47 PM
I think we are all in the same boat on this one (IMG:style_emoticons/default/drunk.gif)
That aftermarket seal doesn't fit so well, needs glue to stay in place, and makes the trunk hard to close at first...can't say I got much water in the front trunk for the 6 months I've gone without it, but better safe than sorry so I have a seal now (IMG:style_emoticons/default/beerchug.gif) |
markb |
Jul 20 2006, 12:49 PM
I glued the corners on mine when I put it in. I think it's normal for a little resistance when new. The rear trunk one is really resistant.
arc914 |
Jul 21 2006, 08:36 AM
I think we are all in the same boat on this one (IMG:style_emoticons/default/drunk.gif) That aftermarket seal doesn't fit so well, needs glue to stay in place, and makes the trunk hard to close at first...can't say I got much water in the front trunk for the 6 months I've gone without it, but better safe than sorry so I have a seal now (IMG:style_emoticons/default/beerchug.gif) Hi Chris arent you in Cally? it doesn't rain there ha. I am at the heart of the great lakes in Sault Ste Marie,ontario,canada lots o wet stuff. I did a re-glue last night and still have the hood trying to bulge up from hinges to hood latch. i will give it some time with the hood closed to see if it settles. how long should i wait till i try another approach?any suggestions? Cheers andrew |
SLITS |
Jul 21 2006, 08:51 AM
After seeing the install of the "aftermarket" seal and what it does to the fit of the hood, I think the better option would be to obtain good used OE pieces and glue them together.
Lo-Fi Version | Time is now: 23rd May 2024 - 06:07 PM |
