One stop transmisison service for less, Questions, rebuilds, diagnoses, etc. |
Dr Evil |
Jul 21 2006, 12:49 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Is your tranny feeling like this?
Send it to me and I will make it feel and perform like this! If your tranny is feeling its age, grinding, and popping out of gear I have the solution for you! If you have checked the other, outside of the tranny causes for these symptoms and found them to be ok then your tranny may be in need of a rebuild. Some outside of the tranny causes for some of your shifting woes: -Shifter bushings along the shift rod -Cone set screws -Tranny cable adjustment, shifter adjustment -Clutch, TO bearing, pressure plate -Engine and tranny mounts So, you have checked all of the above and it is still not working as it should. What do you do!? Send it to me! Repairs, modifications, conversions, you name it. I am interested in getting your car shifting correctly and lasting a long time while providing you with the greatest value and service. If you have questions I would be happy to help you. If you want to take pics of your gear stack and get an opinion feel free to contact me. Do you want to bring it by and have me take it apart to diagnose it? I will gladly do this, and for free. I will diagnose any tranny for no charge. I have a great stock of excellent used internal parts for much less than new with no loss in performance, as well as new, if you are interested. I have many different gear sets. I highly recommend all new main bearings; input shaft (x2), pinion shaft (x2) and differential (x2). I stock these bearing set at far less than retail. For shipping instructions, PM me. Any questions feel free to PM me (IMG:style_emoticons/default/wavey.gif) For more info, click the link to my web page in my sig below. Here is also a link to an excellent thread by DNHunt on how to rebuild the tranny if you want a basic overview http://www.914world.com/bbs2/index.php?sho...=40904&st=0 |
wbergtho |
Apr 17 2008, 09:50 AM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
Hi,
If you do 915's...you must do the 930 as well...correct? I have a pretty fresh 930 box with less than 5000 miles. While setting up the cable shifter and clutch, I managed to burn the 3rd gear synchro a bit. It isn't terrible...but it is annoying when it grinds going into third. If all you do is replace the 3rd gear synchro...how much should that cost (assuming everything else is unmolested)? Thanks, Bill |
Lo-Fi Version | Time is now: 4th May 2024 - 02:02 AM |
