One stop transmisison service for less, Questions, rebuilds, diagnoses, etc. |
Dr Evil |
Jul 21 2006, 12:49 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Is your tranny feeling like this?
Send it to me and I will make it feel and perform like this! If your tranny is feeling its age, grinding, and popping out of gear I have the solution for you! If you have checked the other, outside of the tranny causes for these symptoms and found them to be ok then your tranny may be in need of a rebuild. Some outside of the tranny causes for some of your shifting woes: -Shifter bushings along the shift rod -Cone set screws -Tranny cable adjustment, shifter adjustment -Clutch, TO bearing, pressure plate -Engine and tranny mounts So, you have checked all of the above and it is still not working as it should. What do you do!? Send it to me! Repairs, modifications, conversions, you name it. I am interested in getting your car shifting correctly and lasting a long time while providing you with the greatest value and service. If you have questions I would be happy to help you. If you want to take pics of your gear stack and get an opinion feel free to contact me. Do you want to bring it by and have me take it apart to diagnose it? I will gladly do this, and for free. I will diagnose any tranny for no charge. I have a great stock of excellent used internal parts for much less than new with no loss in performance, as well as new, if you are interested. I have many different gear sets. I highly recommend all new main bearings; input shaft (x2), pinion shaft (x2) and differential (x2). I stock these bearing set at far less than retail. For shipping instructions, PM me. Any questions feel free to PM me (IMG:style_emoticons/default/wavey.gif) For more info, click the link to my web page in my sig below. Here is also a link to an excellent thread by DNHunt on how to rebuild the tranny if you want a basic overview http://www.914world.com/bbs2/index.php?sho...=40904&st=0 |
Dr Evil |
Jul 21 2006, 12:56 PM
How to remove the stack from you tranny out of the car:
Step 1. Remove the shift console and the reverse switch with its pin Step 2. Remove tail cone. Be ready for the reverse gear and its little bearings to fall out. You should now be looking at the business end of the tranny gear stack. Step 3. Select 5th gear by taking a socket extension and pushing in the 4th/5th shift rod. Its ok to use a hammer, just dont beat the hell out of it (IMG:style_emoticons/default/wink.gif) (4th and 5th Shift rod in neutral) (5th gear selected) You can now remove your gear stack by lifting at the intermediate plate. ***NOTE*** When you remove the intermediate plate you will have some gaskets between it and the case. These are of a particular thickness and need to be replaced with the same to keep the pinion shaft depth the same. Use a micrometer to measure the thickness of these (usually more than one) and keep that number handy. When you reinstall you need to measure the gaskets that come with the new kit and replace with ones that are of the same thickness. Also, here is a link to Red-beards article on how to fix 1st with the tranny in the car. It can be used as a guide to how to remove the stack in the car. http://home.san.rr.com/pb914/rebuild/ |
NecronomiconJules |
Oct 26 2007, 02:55 AM
Newbie Group: Members Posts: 7 Joined: 3-January 07 From: CA Member No.: 7,422 |
Dear Doctor,
I have a souped-up 3.0 SC engine mated to a side-shifter 901 with a ZF LSD. Now for the bad news: - 2nd and 3rd grind if shifting occurs anywhere near top RPM's; oh, if I wait > 2 seconds they don't, but by then I'm doing 3 Mph - 1st and reverse grind when engaging from idle after holding the clutch down for < 3 seconds; this one I can live with, and provide FYI I'm a complete mechanical ignoramus, with no hope for reformation any time soon. Can you help me? What happens if surgery reveals terminal condition in there? Can you source parts, etc.? $500 all going well, really? Cheers, J. |
Lo-Fi Version | Time is now: 4th May 2024 - 06:51 AM |
