front suspension woes, what's bend? |
Oct 15 2003, 12:39 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
sooo, i'm getting ready for a alignment of the car and i'm having a problem with my front suspension.
i knew the car was hit in the front. i knew the 911 front suspension came out of a car that was hit in the front. now, the front suspension mount on the pass. side (A-Arm) does not line up correctly. the mount is supposed to be a tight fit with the bushing and the a-arm "stop". but it's about 1/4 to 1/2 inch off. altough it is tight, no play. something is obviously bent. how can i find out if either my tub is bend or if the pass a-arm (or worse, the cross member) is bend? anyone has some measurements? i do have a stress-crack in the chassis right next to that mount. but i'm not sure if that was from the crash or additional stress of a bend suspension or what. help! Andy |
davep |
Oct 15 2003, 01:21 PM
There are measurements in a few places I think. I just saw some on the mittlemotor.de website. I think Pelican Parts also has it on line. Failing them, I have the workshop manuals with all the data at home. You should start looking for a spare set of A-arms. I've seen several rot out over the past several years.
DaveP |
Oct 15 2003, 05:04 PM
The measurements are in the shop manuals. You can also find them at:
http://www.dgi.net/914/914body/914body.html ...And also wherever the mirror on the 914club site is. (IMG:style_emoticons/default/wink.gif) --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 09:16 PM |
