Volt meter doesn't work, Are they fixable? |
KELTY360 |
Jul 23 2006, 10:35 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
The volt meter in the center console of my '74 2.0 doesn't register at all. When I jump across the terminals on the back I get 11.9 with the ignition on and 13+ with the engine running. Does this mean the gauge is bad? Can it be fixed?
The clock and the oil temp gauge work fine. |
lapuwali |
Jul 23 2006, 11:45 PM
The volt meter in the center console of my '74 2.0 doesn't register at all. When I jump across the terminals on the back I get 11.9 with the ignition on and 13+ with the engine running. Does this mean the gauge is bad? Can it be fixed? The clock and the oil temp gauge work fine. 11.9 switch on and 13-ish running is exactly correct. Sounds like the gauge is fine and only the wiring to it is bad. |
anthony |
Jul 24 2006, 01:42 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Yeah, to me it sounds like the gauge is dead.
QUOTE 11.9 switch on and 13-ish running is exactly correct. Sounds like the gauge is fine and only the wiring to it is bad. The wiring to the volt gauge isn't know for it's accuracy. I'd use it more as a relative measure of system voltage. |
KELTY360 |
Jul 24 2006, 08:44 AM
[quote name='anthony' date='Jul 24 2006, 12:42 AM' post='736084']
Yeah, to me it sounds like the gauge is dead. Thanks. Is there a way to fix the gauge or is the fix to find a working one? |
lapuwali |
Jul 24 2006, 08:48 AM
Sorry, I misunderstood what you were saying. I thought you read 11.9 and 13+ off the gauge after you rearranged the wires in the back. Try removing the gauge and connecting it with your own wires directly to the battery terminals, and see what happens.
The gauge can be fixed, but it's probably cheaper to just find a used one that still works. |
KELTY360 |
Jul 24 2006, 08:55 AM
Sorry, I misunderstood what you were saying. I thought you read 11.9 and 13+ off the gauge after you rearranged the wires in the back. Try removing the gauge and connecting it with your own wires directly to the battery terminals, and see what happens. The gauge can be fixed, but it's probably cheaper to just find a used one that still works. Good idea, what's involved in fixing the gauge? |
lapuwali |
Jul 24 2006, 09:13 AM
Sorry, I misunderstood what you were saying. I thought you read 11.9 and 13+ off the gauge after you rearranged the wires in the back. Try removing the gauge and connecting it with your own wires directly to the battery terminals, and see what happens. The gauge can be fixed, but it's probably cheaper to just find a used one that still works. Good idea, what's involved in fixing the gauge? Never had one apart, but it's most likely a simple moving coil meter. The deadness is most likely one of the super fine coil wires has broken. These are very difficult to solder, but you can certainly try your hand at it. A rebuilding shop like PA Speedo will likely have good used parts on hand. They'll charge a good deal more than a complete used one will cost to repair yours, however. |
anthony |
Jul 24 2006, 09:54 AM
Yeah, just find a good used one. Or, if you didn't care about originality you could pop in a VDO gauge.
(IMG:http://www.egauges.com/images/vdo/332-103.jpg) |
KELTY360 |
Jul 24 2006, 11:06 AM
Thanks. Next stop, classifieds.
So.Cal.914 |
Jul 24 2006, 11:14 AM
The volt meter in the center console of my '74 2.0 doesn't register at all. When I jump across the terminals on the back I get 11.9 with the ignition on and 13+ with the engine running. Does this mean the gauge is bad? Can it be fixed? The clock and the oil temp gauge work fine. Those readings seem fine to me, just run your own wires. If you really want to toss some money send it to So.Cal.914 restoration fund, La Quinta, CA. |
KELTY360 |
Jul 24 2006, 12:21 PM
The volt meter in the center console of my '74 2.0 doesn't register at all. When I jump across the terminals on the back I get 11.9 with the ignition on and 13+ with the engine running. Does this mean the gauge is bad? Can it be fixed? The clock and the oil temp gauge work fine. Those readings seem fine to me, just run your own wires. If you really want to toss some money send it to So.Cal.914 restoration fund, La Quinta, CA. The wires are fine, it's the gauge that won't give a reading. Tested it out of the car, direct to the battery - nada. BTW, check is in the mail (ever heard that before?) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:37 AM |
