QUOTE(So.Cal.914 @ Jul 24 2006, 10:14 AM)
QUOTE(KELTY360 @ Jul 23 2006, 09:35 PM)
The volt meter in the center console of my '74 2.0 doesn't register at all. When I jump across the terminals on the back I get 11.9 with the ignition on and 13+ with the engine running. Does this mean the gauge is bad? Can it be fixed?
The clock and the oil temp gauge work fine.
Those readings seem fine to me, just run your own wires. If you really want to
toss some money send it to So.Cal.914 restoration fund, La Quinta, CA.
The wires are fine, it's the gauge that won't give a reading. Tested it out of the car, direct to the battery - nada.
BTW, check is in the mail (ever heard that before?)
