stalling problems, when warm |
rcrgrl |
Jul 24 2006, 11:37 PM
Member Group: Members Posts: 202 Joined: 19-April 06 From: San Diego, CA Member No.: 5,893 |
okay, so finally back at my 914.... it starts fine, runs fine, but when it warms up, won't idle, and sometimes has very poor throttle response from a stop.
i have: - checked for vacuum leaks with carb cleaner, (then w/ water - thanks Joe) can't seam to find any - checked the timing and it seems ok, but since the marks are gone, this is my best guess with a matchbook cover - any suggestions on re-setting those marks and getting a better set? although, i don't really think timing is off. - pulled the plugs and they say lean - still haven't figured that out, seems it should be rich, not lean. - oh yeah, and dumped and ran a bottle of FI cleaner, -replaced the fuel filter i also replaced the PCV valve recently because the idle was too high, but i don't see how that could be related. anyway, before i start randomly changing stuff - i was hoping for some expert direction. i don't think its a sensor, cause it runs fine at speed, it just doesn't idle (IMG:style_emoticons/default/WTF.gif) thanks guys in advance for your help! j |
ThinAir |
Jul 24 2006, 11:59 PM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Sounds like you have not adjusted the valves. If it runs fine cold, but won't run once it warms up, then it is often tight valves. So many other things depend upon proper valve adustment that it's probably the first thing to check before hunting for any other causes (especially ones that involve replacing parts).
JoeSharp |
Jul 25 2006, 07:26 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Race: What plug are you running?
;PERMAGRIN: Joe |
rmital |
Jul 25 2006, 07:47 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
okay, so finally back at my 914.... it starts fine, runs fine, but when it warms up, won't idle, and sometimes has very poor throttle response from a stop. ......I had the same "exact" condition before this weekend....my car started great cold, ran like a champ till warm. Still ran great, bad idle at stops wanting to stall. check my dwell angle...it was high, got it around 45^, the car runs great. |
rcrgrl |
Jul 25 2006, 11:01 AM
thanks guys.
i have adjusted the valves. 2x's just to be sure (IMG:style_emoticons/default/smile.gif) joe- not sure, champion something, i'll check and i'll check the dwell tonight and report back..... |
JoeSharp |
Jul 25 2006, 12:06 PM
Race: Put some NGK B7ES's in there, they are the cold plug for us.
:PERMAGRIN: Joe |
Jeffs9146 |
Jul 25 2006, 02:02 PM
If it is injected then the problem is the cylinder head temp sender. It adjusts the fuel air mixture when the car warms up. If it is not working the car will run too rich and stall out!
Jeff |
rmital |
Jul 25 2006, 02:08 PM
Jeffs9146 |
Jul 25 2006, 02:25 PM
QUOTE ...that's why I didn't think it was the CHT....sensor bad, it craps out at speed from running too rich. Not always! Mine ran fine until you came to a stop sign and the idle dropped. It could be failing! Jeff |
brownaar |
Jul 25 2006, 02:30 PM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
How old are your points? Seems to me I had a problem with old points when mine would heat up at one point.
mightyohm |
Jul 25 2006, 02:55 PM
Here are my thoughts:
My gut feeling is that it is running rich when it warms up. Verify the ignition system is working properly first, including timing/dwell. Check fuel pressure, adjust if necessary. Check CHT sensor. Is IAT sensor connected and working? Check operation of injectors. Are any stuck open? Is cold start injector stuck open? Make sure MPS and other vacuum hoses are in good shape. Test MPS to make sure it is not leaking down. |
Jeffs9146 |
Jul 25 2006, 03:17 PM
On mine, the threads were stripped and the sensor would sometimes make contact and other times not. I coiled the threads and put in a new sensor and all was well!!
Jeff |
rcrgrl |
Jul 26 2006, 10:28 PM
so - i've actually got bosch plugs in there (the champions are on the other car) and they are white - definately running lean. this confuses me though, as lean should make it idle high right?
at the risk of sounding like i have no clue - cause i don't - how do i test the CHT sensor - this is the one by the #3 plug rigth? dwell is fine, btw thx j |
rcrgrl |
Jul 27 2006, 11:06 PM
so now it won't start at all.
i have unplugged the fuel pump, taken out the fuel filter, replaced a section of fuel line, put the fuel filter back in, and plugged back in the fuel pump now it won't start at all. um - maybe i put the fuel filter in backwards, but i don't think so, and there is gas at the fuel rail when you turn the engine over. and you can hear the pump prime. and there is spark (IMG:style_emoticons/default/WTF.gif) i'm going now to (IMG:style_emoticons/default/beer3.gif) and maybe (IMG:style_emoticons/default/beer3.gif) |
sk8kat1 |
Jul 28 2006, 12:22 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
On mine, the threads were stripped and the sensor would sometimes make contact and other times not. I coiled the threads and put in a new sensor and all was well!! Jeff hey my car is doing the same thing and my head sensor is slightly stripped too.. what was this cioling thing your are talking about .. how do you do that?! |
Jul 28 2006, 01:43 PM
so now it won't start at all. i have unplugged the fuel pump, taken out the fuel filter, replaced a section of fuel line, put the fuel filter back in, and plugged back in the fuel pump now it won't start at all. um - maybe i put the fuel filter in backwards, but i don't think so, and there is gas at the fuel rail when you turn the engine over. and you can hear the pump prime. and there is spark supply and return line switched ... supply goes to the pass. side fuel rail, return comes from the pressure regulator on the drivers side ... you mix them up, car won't start ... (IMG:style_emoticons/default/smile.gif) Andy |
Jeffs9146 |
Jul 31 2006, 04:39 PM
QUOTE what was this cioling thing your are talking about .. how do you do that?! It is a Heli-coil basicly you repair the threads with a Heli-coil. It is a tough angle to get to with the motor in but you can do it. The directions are on the box of coils. You drill out the old threads and put in new ones. Jeff |
rcrgrl |
Jul 31 2006, 09:33 PM
so now it won't start at all. i have unplugged the fuel pump, taken out the fuel filter, replaced a section of fuel line, put the fuel filter back in, and plugged back in the fuel pump now it won't start at all. um - maybe i put the fuel filter in backwards, but i don't think so, and there is gas at the fuel rail when you turn the engine over. and you can hear the pump prime. and there is spark supply and return line switched ... supply goes to the pass. side fuel rail, return comes from the pressure regulator on the drivers side ... you mix them up, car won't start ... (IMG:style_emoticons/default/smile.gif) Andy .. don't the supply/return lines connect directly to the fuel pump - i didn't take any lines off the fuel pump, just the fuel filter? i'm so frustrated - no idea where to go from here - just seems to be getting worse |
rcrgrl |
Aug 1 2006, 12:11 AM
yeah - fixed. the wire to the CHT was busted way down by where it meets up with the other wires, so i didn't see it first time. fixed it and it started right up.
tomorrow's forcast - (IMG:style_emoticons/default/driving-girl.gif) thank you everybody for your help!!! |
ptravnic |
Aug 1 2006, 07:02 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
rcrgrl - For future reference, print out Brad Ander's troubleshooting guide(s). I've found them tremendously usefull. The only downside is that there is sometimes a lot to read but it's chock-full of hints and tricks of the trade.
http://members.rennlist.com/pbanders/ -pt |
Lo-Fi Version | Time is now: 21st May 2024 - 11:44 PM |
