1975 2.0 liter exhaust system, Need pics of original 1975 2.0 liter exhaust |
copilot |
Jul 26 2006, 11:21 AM
Newbie Group: Members Posts: 7 Joined: 22-July 06 From: Canada Member No.: 6,486 |
I have located two pieces of what appears to be an original exhaust system for my 1975 2.0 liter. There is an outlet on each muffler that I don't know their purpose (or even if they are original). If anyone could email me a couple of pictures of an original 1975 2.0 liter exhaust system I would really appreciate it. Thanks.
Bleyseng |
Jul 26 2006, 11:25 AM
the bottom HE is for the 75-76
copilot |
Jul 26 2006, 11:41 AM
the bottom HE is for the 75-76 Thanks for the fast reply and the HE information. The parts I am trying to figure out are the two mufflers that attach to the HE's. One muffler has an outlet with a flange that looks like something that would connect to a VW type 1 heat riser and the other has a small welded up 1/4" outlet. |
Rand |
Jul 26 2006, 12:00 PM
I'm thinking that welded-up hole was the tap for the egr valve?
Bleyseng |
Jul 26 2006, 12:26 PM
#22
copilot |
Jul 26 2006, 12:53 PM
#22 Many thanks Geoff! Looks like I have found the original mufflers I need. Do you happen to know what conects to the small outlet above the main pipe on 1A? It looks like I am missing parts 19 through 22. Unfortunately, I have to re-smog my car for the local authorities. Attached image(s) |
Bleyseng |
Jul 26 2006, 02:56 PM
Maybe you are talking about the EGR pipe that everyone tossed as soon as possible? It went from the air cleaner to the muffler in that little pipe. Wasn't that Calif only???? It sure was on my 77 Westy.
Factory manual pic of the 75 muffler (IMG:style_emoticons/default/cool_shades.gif) Attached image(s) |
ejm |
Jul 26 2006, 03:24 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE Do you happen to know what conects to the small outlet above the main pipe on 1A? That was a test port to check emissions ahead of the cat. Part 24 was a cap for it. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:14 AM |
