Threshold Plate and Outer Rocker Rivet kits, oem substitute - OUT OF STOCK |
tod914 |
Jul 28 2006, 10:39 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Currently out of stock - sourcing another manufacturer I have available NLA Black and Bone colored plastic rivets for use on the threshold plates and outer rocker panels. The costs are 20 cents per rivet plus $4 shipping per order. For 1970-1973 model year cars with aluminum threshold plates you will need 36 bone (white) colored rivets. For 73 1/2 through 1976 model year cars with black plastic threshold plates, you will need 24 black for the threshold plates, and 12 bone colored rivets for the outer rockers. Some original owner 75-76 model year cars had metal pop rivets holding on the outer rockers. You may want to go with all black for your 75-76 model year car. We were unable to confirmed if all 75-76 model year cars came that way. Oem rivets (clear only) costs .80 cents per rivet for a total of $28.80 for 36 clear rivets. Here you can do the same job for $7.20 plus $4 shipping . ** NOTE ** SHIPPING WILL BE WITH CERTIFIED MAIL ONLY FROM NOW ON. Sorry for the increase but I refuse to take a hit each time an order doesn't make it's destination. This seems to happen more often than not. Keep in mind, althought the heads are a perfect match, one or two prongs may or may not have to be razored/cut off at the base for it to fit, being they are slightly thicker than OEM. Test fit before you get into cutting. You may find that they will go in with all 4 prongs without a problem. Be sure to order a few extra to do your car in case of mistake while installing. Installation tips are below. PM me for payment information and specify amount and color. Thanks for your interest. |
tod914 |
Jul 30 2006, 09:26 AM
Here are some tips on how to install the rivets on the outer rocker panels. I would suggest the 1st method. This will allow you to remove your outer rocker panels while leaving the rivets intact.
Step 4. pull out the pin then insert the rivet head. push in pin |
tod914 |
Aug 20 2006, 11:10 AM
RIVET INSTALLATION... METHOD 2
mpissaquah |
Jul 24 2007, 07:26 PM
Mike P Group: Members Posts: 31 Joined: 24-September 05 From: Sammamish, WA Member No.: 4,857 Region Association: None |
I have available NLA Black and Bone colored plastic rivets for use on the threshold plates and outer rocker panels. The costs are 20 cents per rivet plus $3 shipping per order. For 1970-1973 model year cars with aluminum threshold plates you will need 36 bone (white) colored rivets. For 73 1/2 through 1976 model year cars with black plastic threshold plates, you will need 24 black for the threshold plates, and 12 bone colored rivets for the outer rockers. Some original owner 75-76 model year cars had metal pop rivets holding on the outer rockers. You may want to go with all black for your 75-76 model year car. We were unable to confirmed if all 75-76 model year cars came that way. Oem rivets (clear only) costs .80 cents per rivet for a total of $28.80 for 36 clear rivets. Here you can do the same job for $7.20 plus $3 shipping. Keep in mind, althought the heads are a perfect match, one or two prongs may or may not have to be razored/cut off at the base for it to fit, being they are slightly thicker than OEM. Test fit before you get into cutting. You may find that they will go in with all 4 prongs without a problem. Be sure to order a few extra to do your car in case of mistake while installing. Installation tips are below. PM me for payment information and specify amount and color. Thanks for your interest. DO you still have the black rivits available? I woudl be intersted in 24 for my 75 914 |
914werke |
May 9 2008, 12:51 PM
"I got blisters on me fingers" Group: Members Posts: 10,081 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
JazonJJordan |
Jul 25 2009, 03:31 PM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
(IMG:style_emoticons/default/biggrin.gif) Wow Tod914, great NLA product at a great price! Thanks for the good work~ (IMG:style_emoticons/default/smash.gif) (Rivet Smasher!)
BarberDave |
Dec 21 2009, 03:01 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I 'll take a set of black for my 73. P.M. you with addy> Thanks Dave (IMG:style_emoticons/default/slap.gif) |
chrispy |
Jan 3 2010, 03:39 PM
Newbie Group: Members Posts: 48 Joined: 5-May 09 From: modesto, ca Member No.: 10,337 Region Association: None |
I'm interested in purchasing 40 or the white plastic rivets for my 1972 914. Contact me with purchase information. Thanks so much!
Chris Poulsen pcpoulsen@aol.com |
rfuerst911sc |
Apr 18 2010, 11:01 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
PM sent for black rivets.
Lo-Fi Version | Time is now: 20th May 2024 - 01:14 PM |
