Currently out of stock - sourcing another manufacturer
I have available NLA Black and Bone colored plastic rivets for use on the threshold plates and outer rocker panels. The costs are 20 cents per rivet plus $4 shipping per order. For 1970-1973 model year cars with aluminum threshold plates you will need 36 bone (white) colored rivets. For 73 1/2 through 1976 model year cars with black plastic threshold plates, you will need 24 black for the threshold plates, and 12 bone colored rivets for the outer rockers. Some original owner 75-76 model year cars had metal pop rivets holding on the outer rockers. You may want to go with all black for your 75-76 model year car. We were unable to confirmed if all 75-76 model year cars came that way. Oem rivets (clear only) costs .80 cents per rivet for a total of $28.80 for 36 clear rivets. Here you can do the same job for $7.20 plus $4 shipping . ** NOTE ** SHIPPING WILL BE WITH CERTIFIED MAIL ONLY FROM NOW ON. Sorry for the increase but I refuse to take a hit each time an order doesn't make it's destination. This seems to happen more often than not.
Keep in mind, althought the heads are a perfect match, one or two prongs
may or
may not have to be razored/cut off at the base for it to fit, being they are slightly thicker than OEM.
Test fit before you get into cutting. You may find that they will go in with all 4 prongs without a problem. Be sure to order a few extra to do your car in case of mistake while installing. Installation tips are below. PM me for payment information and specify amount and color.
Thanks for your interest.
