Asphalt sound deadening, can o worms |
914werke |
Jul 28 2006, 02:57 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Is the precut stuff listed anywhere I didnt see it in PET.
and yes Im considering installing it back on the car. |
Pat Garvey |
Jul 28 2006, 06:57 PM
Is the precut stuff listed anywhere I didnt see it in PET. and yes Im considering installing it back on the car. Why? Don't like the sounds from behind? Like the thought of that stuff absorbing moisture with only the wrong way out? Don't do it man! Just listen to that glorious mechanical noise - that's why you don't need a radio at all (IMHO). |
914werke |
Jul 29 2006, 12:31 AM
Mechanical noise I can deal with but the sound of rocks ritcocheting of the unprotected and un muffeled floorpans ..... (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/wacko.gif)
No thanks. As for moisture, the cars originally had this stuff put down on unpainted panels then sprayed. I have already primed and painted the entire car, including the interior. I figure installing the sound deadening *over* the paint then sprayed to match with provide added protection from the tin worm. |
tod914 |
Jul 29 2006, 09:43 AM
There's info on this in the garage forum.. dont have time to look but try there
Jul 29 2006, 12:33 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I figure installing the sound deadening *over* the paint then spreayed to match with provide added protection from the tin worm. the bodyshop that did the frame pulling on my /6 has a product that is sprayed on, but it's *not* bedliner, in fact, it turns out to be pretty damm close to the original tar on the floorboards. you just mask off the areas where you don't want the tar and spray it on ... i forgot what it's called, but i can swing by and ask ... (IMG:style_emoticons/default/smile.gif) Andy |
KenH |
Aug 1 2006, 04:42 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
I figure installing the sound deadening *over* the paint then spreayed to match with provide added protection from the tin worm. the bodyshop that did the frame pulling on my /6 has a product that is sprayed on, but it's *not* bedliner, in fact, it turns out to be pretty damm close to the original tar on the floorboards. you just mask off the areas where you don't want the tar and spray it on ... i forgot what it's called, but i can swing by and ask ... (IMG:style_emoticons/default/smile.gif) Andy I would like to know what they used. The PO removed all the coating from the outside bottom of the car. I need to put something back on. Ken |
Crazyhippy |
Aug 1 2006, 06:10 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
possibly Rocker Schutz?? It's designed for the lower rockers on modern cars.
BJH |
Lo-Fi Version | Time is now: 27th April 2024 - 10:39 PM |
