Turbo Tie-Rod Problems, HEEEEELLLLPPPPP!!! |
Allan |
Jul 28 2006, 07:02 PM
anthony |
Jul 28 2006, 07:30 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
QUOTE He doesnt need the spacers he has in place. He has 911 struts so the spacers are not required. When do you use the spacers or not use the spacers? |
Aaron Cox |
Jul 28 2006, 08:44 PM
brad... uh.. i have the spacers and 911 struts......
914-8 |
Jul 28 2006, 09:01 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
Just curious...what parts are wrong? Are there different TTR's? I believe there are different Turbo tie rods. The Turbo cars use a different steering rack than a normal 911. So there are "Turbo" tie rods that are made to be used with a Turbo steering rack. And "Turbo" tie rods made to be used with a non-Turbo steering rack. At least that's what I've read. Feel free to correct if wrong! |
Dr Evil |
Jul 28 2006, 09:50 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Brando |
Jul 28 2006, 10:01 PM
I have the spacers and turbo tie rods...
John |
Jul 28 2006, 11:57 PM
What spacers?
Rack spacers for bump steer? 10mm thick ones? I have them in mine with Turbo Tie rods and 911 struts. I had no problems. It sure looked like his suspension came down a very long way. I don't believe that mine came down that far. |
Brad Roberts |
Jul 29 2006, 03:35 AM
OK.
There is ONE part number for the 75-89 930 Turbo Tie Rods: 930.347.322.00 The 930 DOES use a different steering rack (but it uses spacers also) The 911's up until 1989 use a 914.347.010.06 steering rack. A 4cyl car with 4 lug struts has to use the spacer or you end up with 3-4 threads in the end of the tie rod (not safe in my book) The 911 struts have a different arm on the strut tube. It can go either way (with or without) depending on whether or not you want bind in full droop lock to lock. If your dont want bind in that "rare" occasion... then pull the spacers out. Funny "914-8" your didnt happen to write that did you ?? (IMG:style_emoticons/default/beerchug.gif) B |
Eric_Shea |
Jul 29 2006, 08:39 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Koni Struts w/Spacers here.
QUOTE What spacers? Rack spacers for bump steer? 10mm thick ones? I have them in mine with Turbo Tie rods and 911 struts. I had no problems. Spacer that go between the rack and the tie-rod. Not bump steer. |
Lo-Fi Version | Time is now: 4th June 2024 - 09:23 AM |
