> Deceleration valve on the D-jet
lmcchesney
post Jul 29 2006, 02:43 PM
Does the D-jet use a deceration valve? I have seen diagrams with and without. If it does use the valve, where do you mount the valve?
Thanks,
Larry
post Jul 29 2006, 02:51 PM
Resident German
QUOTE(lmcchesney @ Jul 29 2006, 01:43 PM) *
yes, it certainly does ... mine was mounted next to the throttle body, kinda between the TB and the oil filler neck.
but i don't know for sure if that is the stock location ...
however, the decel-valve is not critical for engine operation, just smoothes out the off-gas transition ...
i removed it and the cold start valve as well from my engine. less clutter, less potential for air-leaks, better off throttle response (faster wind-down of RPMs) ...
(IMG:style_emoticons/default/smile.gif) Andy
kpex914
post Jul 29 2006, 06:28 PM
(IMG:style_emoticons/default/agree.gif) it mounts on the passenger side and uses the top screw for the mps
Bleyseng
post Jul 29 2006, 06:31 PM
Aircooled Baby!
Yep, mounts right above the MPS on the same top screw. I take them off as the fittings/rubber elbows are usually shot and vacuum leaks. (IMG:style_emoticons/default/biggrin.gif)
lmcchesney
post Jul 31 2006, 06:44 AM
Thanks Guys,
The MPS is mounted upside down for the time while I get the LC-1 in and adjust the A/F ratio.
I suspect I'm running rich, in that I get a backfire with deceleration.
BUT, it is running.
Larry
- Lo-Fi Version Time is now: 27th November 2026 - 05:33 PM
