Fuel Pump Location, Pictures needed |
tracks914 |
Oct 17 2003, 06:22 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
When I bought my car the fuel pump was hanging from the hell hole with ty-raps. It has all been rebuilt and I want to know where it came from originally. ('72) Wires pointed up or down, fuel filter location etc. I am trying my best to put the car back in original condition and don't want things where they aren't supposed to be.
tracks914 |
Oct 17 2003, 06:39 PM
I saw this picture (not my car, too much steel left in the hell hole) but cannot quite figure out the orientation of the mounts.
415PB |
Oct 17 2003, 08:43 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
Just took this pic a week ago before pulling the fuel pump. Electrical connections are facing down.
415PB |
Oct 17 2003, 08:44 PM
Hope it helps.
boxstr |
Oct 17 2003, 08:53 PM
Porsche in 1975-76 relocated the fuel pump,removing it from the area below the hell hole. The reason was the fuel pump was located in an area that would heat the fuel and cause vapor lock, amongst other problems.
It may be original, but it is not the best place to have your fuel pump located. The closer to the fuel tank I have read is better, thus the factory relocated in 1975-76 the fuel pump behind a small plate to the front of the car under the fuel tank, along with the fuel filter. CCLINVAPORVILLE |
tracks914 |
Oct 18 2003, 07:26 AM
QUOTE(415PB @ Oct 17 2003, 06:44 PM) Hope it helps. Is the clip behind the fuel filter meant to hold the fuel filter? I didn't know what it was for. Was the vapor locking only in hot Californian weather or did it happen all the time? |
TheCabinetmaker |
Oct 18 2003, 08:43 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
My 73 used to vapor lock any time over 95 degrees Farenhiet, but that's not the only problem. The pump sits where the heater valve dumps hot air almost directly on it. I moved it to the front trunk. Prob went away. If yours has never locked, don't worry about it till it does.
tracks914 |
Oct 18 2003, 08:47 AM
QUOTE(vsg914 @ Oct 18 2003, 06:43 AM) If yours has never locked, don't worry about it till it does. I've driven the car about 6 miles the day I test drove it. It was about 40*F out that day. I then trailered it home and stripped it down the bare metal for a "frame up" restoration. I don't know if it even locked up or not. (IMG:style_emoticons/default/blink.gif) Tx Doug |
TheCabinetmaker |
Oct 18 2003, 08:52 AM
If your going to move it, now would be the time. You should also replace allthe fuel lines. Best place to relocate it is above the belly pan under the tank, but gives limited future access.
415PB |
Oct 18 2003, 08:57 AM
Doug, the fuel filter fits into the clip and holds it in place.
tracks914 |
Oct 19 2003, 03:50 PM
Anybody have two of those nice rubber mounting studs for sale?
Lo-Fi Version | Time is now: 10th June 2024 - 01:01 AM |
