my longs, attn craig, jim. lots o picts, pls wait |
rhodyguy |
Oct 17 2003, 08:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
in prep for the front end work i pulled the rockers and went to the steam cleaners. the car looked good as i did all the other work. i was dreading this portion, but (IMG:style_emoticons/default/smile.gif) . look for your selves. the pass side will come last.
kevin "if it jams-force it. if it breaks it needed replacing anyway" Attached image(s) |
rhodyguy |
Oct 17 2003, 08:15 PM
asd
rhodyguy |
Oct 17 2003, 08:17 PM
fgh
rhodyguy |
Oct 17 2003, 08:19 PM
zxc
rhodyguy |
Oct 17 2003, 08:20 PM
qwe
rhodyguy |
Oct 17 2003, 08:22 PM
pass side. what's missing?
rhodyguy |
Oct 17 2003, 08:23 PM
rhodyguy |
Oct 17 2003, 08:24 PM
rhodyguy |
Oct 17 2003, 08:26 PM
now it gets ugly.
rhodyguy |
Oct 17 2003, 08:32 PM
nice work (IMG:style_emoticons/default/mad.gif)
for you locals who can't make it down during the week. i asked the fellow at airport steam cleaning if he works on sat. yes, if you give him a call to set it up. the BEST $54.45 you will spend. esp for you upcoming winter projects. kevin "nature always sides with the hidden flaw" Attached image(s) |
Bleyseng |
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Hmmm, AC car.
Time to junk it due to rust, dude. Geoff |
boxstr |
Oct 17 2003, 08:47 PM
Kevin I think you should get out the wax, and buffer and polisth theose longs until they gleam. Then go to the drawing board and TAP Plastics, get a couple of lengthes of clear plastic and cut them and then heat and bends them to fit in place of your black solid metal rocker covers. That way you can show the restr of us what original longs are supposed to look like.
Goo djob. CCLINLONGINGFORYOU |
Jeroen |
Oct 17 2003, 09:17 PM
Katmanken |
Oct 18 2003, 08:14 AM
Nice to finally see somebody with a decent car after all those horrifying photos! (IMG:style_emoticons/default/dance.gif)
I second the clear rockers, show it if ya got it! I was beginning to believe that my car was the only one with a decent set of longs. As per that little blemish, fix it- it's only surface rust. Yep, I'm going to give this one an honorary "rust free California Car" rank- even if it's from Podunk! (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) Ken |
rhodyguy |
Oct 18 2003, 08:36 AM
thanks. it IS a cal car!! it came to me from the sacramento area via portland(thanks j&c). i hope restoration designs has the triangular supports for the sill and the front cover piece they hacked away to run the ac lines. the weld list is growing. nothing too major. i will remove the small sections of seam seal just to be sure. i breathed a sigh of relief when the rockers came off. i always get carried away with these projects. clean, treat rust, self etch prime, and rattle can. i still have some color match silver left. then blast the rockers, paint those, the rear val, and a front one (if i can locate one that is suitable). i believe semi-flat black is pretty close.
kevin kevin |
Charles Deutsch |
Oct 18 2003, 10:46 AM
Unregistered |
My passenger side longitudinals are completely solid too but the area beneath the battery is another story. My car was originally from California - if only the previous owners would've taken the battery out occasionally and sprinkled a little baking soda around the area and then hosed it off, my car would be mostly rust free.
(IMG:http://persweb.direct.ca/aschwenk/F1040020.jpg) (IMG:http://persweb.direct.ca/aschwenk/F1040014.jpg) |
Bleyseng |
Oct 18 2003, 10:51 AM
It will take you alittle work Alfred, but soon it will look like this.
Geoff Attached image(s) |
Charles Deutsch |
Oct 18 2003, 11:09 AM
Unregistered |
Looks good. Do you have any "before" pictures?
Bleyseng |
Oct 18 2003, 11:26 AM
It wasn't too bad. Just some rust on the cutup engine shelf and a few rust holes on the inner wheel house. I stored the car while I went thru a divorce, got pushed outside by my friend where it was stored for over a year. The car filled up with water (parked under a downspout) and leaves cuz they looked at the engine and left it open including taking the car cover off.
Geoff |
rhodyguy |
Oct 18 2003, 03:06 PM
geoff, how badly did you beat that ex-friend? downspout, leaves, lid open (IMG:style_emoticons/default/mad.gif)
kevin |
Lo-Fi Version | Time is now: 9th June 2024 - 09:36 PM |
