DAPO Trick?, Advice please |
HarveyH |
Aug 1 2006, 05:33 AM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Fixing a fuel hose leak on a carbed car and found these:
They were used on Holley fuel pressure regulator, with no hose clamps; the leakage was at the carb end of the hose though. Are these something special for fuel systems or am I better off using a standard hose barb fitting? Thanks, Harvey Attached image(s) |
tdgray |
Aug 1 2006, 06:44 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Looks like a hose repair fitting...as in garden hose.
Ditch it and get some standard barbed fittings and good clamps. |
Cap'n Krusty |
Aug 1 2006, 08:09 AM
Looks like a hose repair fitting...as in garden hose. Ditch it and get some standard barbed fittings and good clamps. To you it might look like that, but to me it looks like a "push loc" fitting for automotive use. Takes special hose, though, which I'm sure it didn't have. Used properly, it works much better than that SS braided cr*p. The Cap'n |
Joe Bob |
Aug 1 2006, 08:18 AM
Use steel braided hose and die....
The push on lock stuff is pretty good....as long as the proper hose and barb end are used. |
Rotary'14 |
Aug 1 2006, 08:19 AM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
QUOTE QUOTE(tdgray @ Aug 1 2006, 05:44 AM) To you it might look like that, but to me it looks like a "push loc" fitting for automotive use. Takes special hose, though, which I'm sure it didn't have. Used properly, it works much better than that SS braided cr*p. The Cap'n (IMG:style_emoticons/default/agree.gif) But the PO might have had the correct hose, it was the other side of the hose that was leaking. -Rob |
Root_Werks |
Aug 1 2006, 09:18 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Yup, I have used that fitting/hose combo before. It works really well, just gotta use the right hose. (IMG:style_emoticons/default/wink.gif)
tdgray |
Aug 1 2006, 09:22 AM
Hmmm learn something new everyday (IMG:style_emoticons/default/smile.gif)
HarveyH |
Aug 1 2006, 11:24 AM
Actually, it was just the cloth braid covered 8mm ID (?) rubber hose forced over the regulator fittings with aircraft clamps at the carb fittings. (IMG:style_emoticons/default/sad.gif)
Maybe I'm lucky I didn't burn... Thanks, Harvey |
Aaron Cox |
Aug 1 2006, 01:03 PM
google "aeroquip socketless blue"
a great alternative to AN braided lines |
East coaster |
Aug 1 2006, 06:10 PM
Senior Member Group: Members Posts: 1,673 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
OK......I'll bite, what's wrong with SS braided fuel lines??
Lo-Fi Version | Time is now: 19th May 2024 - 10:41 PM |
