Automatic 914 |
Automatic 914 |
Bleyseng |
Aug 2 2006, 07:03 PM
How 'bout flipping the whole damn diff section???? Like this. See Shoptalk link
http://shoptalkforums.com/viewtopic.php?t=...asc&start=0 Attached image(s) |
bondo |
Aug 2 2006, 07:12 PM
Neato.. inboard brakes!
I've sort of wondered about vanagon trannies for 914 use, because I see them a lot at work. Lots of gearing options available, and apparently they can be built pretty strong. |
byndbad914 |
Aug 2 2006, 07:24 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
Neato.. inboard brakes! Are they inboard brakes? I have been looking at that setup and I don't see any type of suspension? Looks to me like the output flanges end up mating to that big chunk of aluminum plate, then the outputs with brakes are there - otherwise why the wheel studs and spacers on that hub? So I don't get it, how does the suspension work? Building a "rigid" chopper version of the 914 (IMG:style_emoticons/default/confused24.gif) edit - notice the solid brake line too, so that outer hub ain't movin'.... |
bondo |
Aug 2 2006, 07:29 PM
Neato.. inboard brakes! Are they inboard brakes? I have been looking at that setup and I don't see any type of suspension? Looks to me like the output flanges end up mating to that big chunk of aluminum plate, then the outputs with brakes are there - otherwise why the wheel studs and spacers on that hub? So I don't get it, how does the suspension work? Building a "rigid" chopper version of the 914 (IMG:style_emoticons/default/confused24.gif) edit - notice the solid brake line too, so that outer hub ain't movin'.... Good point.. it looks like a suspensionless (and somewhat narrow) dragster of some sort. So they aren't really inboard brakes. The problem with that setup is the same as turning the whole trans upside down (like you have to do with a G50). You either have steep axle angles, or you have oil pan clearance problems. You can always go dry sump though (like the Ultimas). |
rick 918-S |
Aug 2 2006, 07:50 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
That thead is awesome! I think the Govener passage could be threaded at the mating surface and capped. Then a fitting could be drilled and tapped from the outside of the case halves and a external hard line run to complete the connection. Easy peasy.... (IMG:style_emoticons/default/idea.gif)
Didn't notice the steep axle angle thing... (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/blink.gif) |
byndbad914 |
Aug 2 2006, 07:53 PM
yeah, so I clicked on the imbedded link in the first post and started reading the other forum thread - out of a 500Hp dragster apparently...
Lo-Fi Version | Time is now: 19th May 2024 - 03:54 PM |
