QUOTE(byndbad914 @ Aug 2 2006, 06:24 PM)
QUOTE(bondo @ Aug 2 2006, 06:12 PM)
Neato.. inboard brakes!
Are they inboard brakes? I have been looking at that setup and I don't see any type of suspension? Looks to me like the output flanges end up mating to that big chunk of aluminum plate, then the outputs with brakes are there - otherwise why the wheel studs and spacers on that hub?
So I don't get it, how does the suspension work? Building a "rigid" chopper version of the 914
edit - notice the solid brake line too, so that outer hub ain't movin'....
Good point.. it looks like a suspensionless (and somewhat narrow) dragster of some sort. So they aren't really inboard brakes.
The problem with that setup is the same as turning the whole trans upside down (like you have to do with a G50). You either have steep axle angles, or you have oil pan clearance problems. You can always go dry sump though (like the Ultimas).
