2.0 Injectors in a 1.7, Is this a bad idea? |
Eric Taylor |
Oct 18 2003, 03:00 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
It seams that my 1.7 has a dirty injector. I've run a fair amount of injector cleaner through it, and nothing seams to be happening. I have a set of good 2.0 injectors on the wreck, so the cheap side of me says to just pull them and put them in the 1.7. Is this a bad idea?
davep |
Oct 18 2003, 03:22 PM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
It is a bad idea because the flow rate of the injector is wrong. The engine will run rich, and I do not think that can be adjusted out. There are many of us that would trade a 1.7 injector for a 2.0 injector; I certainly have lots of them available.
DaveP |
Eric Taylor |
Oct 18 2003, 04:47 PM
Does anyone have a good working set of 1.7 injectors?
2teeners |
Oct 18 2003, 04:48 PM
Member Group: Members Posts: 79 Joined: 2-January 03 From: Arlington DFW, TX Member No.: 78 |
I once tried that, and it went way rich, black plugs and all. As Dave said, there should many available around. I've got some too.
Bruce Allert |
Oct 18 2003, 04:57 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
When I bought my 914 with its 1.7 I was doing some cleaning & noticed there were 2.0 injectors. I had heard the same as davep said. Different volume, will run rich so I went on a search for a set of 1.7 injectors. Got them & put them in. Car wouldn't run right. I changed the Head temp sensor... nadda. changed points, still ran crappy, I spent about $200 on electrical change outs & it still ran bad. Even cleaned the injectors multiple times. So, I put the 2.0's back in & it ran better than when I got it. (I even put in Pertronics ignition!) So, I figure if ya got good 2.0 injectors what's it gonna hurt to try. If it runs better than it is now.... GOOD. At least you can drive it until you find a good set of 1.7's, eh?
bruce |
Eric Taylor |
Oct 18 2003, 05:03 PM
Bruce, sounds very encouraging! Are you currently running the 2.0's? I hope my car will run well again sometime
Thanks, Eric |
kdfoust |
Oct 19 2003, 11:49 AM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
My 1.7 had 2.0 injectors in it when I bought it. It had a nasty stumble at low RPMs with the 2.0s. I replaced them with 1.7s and the stumble disappeared. YMMV.
Kevin |
fiid |
Oct 19 2003, 11:55 AM
You ought to be able to change the mixture by adjusting the fuel pressure to accomodate the higher flow rate. Also - I think the 2.0 injectors are peak and hold where the earlier ones are not, but I don't know if that will make a difference.
FI tuning is fun! Fiid. |
davep |
Oct 19 2003, 11:58 AM
Eric,
I hope you are soon able to find some injectors. If not, then just ask. BTW, while you are at it, always replace the rubber seals on the tips. Heat and age cause them to shrink and leak air resulting in all sorts of problems (mostly, lean running). DaveP |
Bruce Allert |
Oct 19 2003, 03:39 PM
Yup, still got the 2's in and it runs gud (IMG:style_emoticons/default/smile.gif) And ditto what DaveP said, change the rubbers. They're cheap on Pelican.
bruce |
Lo-Fi Version | Time is now: 9th June 2024 - 05:21 PM |
