Build your own Combo (904) Gauge, Parts 1 and 2 |
914forme |
Apr 23 2006, 06:48 PM
Well here it goes the step by step instructions on how to build one of the kits. Since I helped do the original production run, back in the day, its been about 11 years ago since we did these. But there is interest in it so I will show you how.
Step one, the original kit. It included a gauge face, a backing plate and a ground lug. Also included instructions on how to do this, and some of the items where real PITAs to do. I will included some changes I do, and items that might make the installation a little easier. Attached image(s) |
914forme |
Apr 23 2006, 08:15 PM
Next up we must remove all the light bulb tube holders. If you have not removed the light bulb sockets yet now i the time. Some might be stuck after 30 odd years, just use a pair of pliers and gentle twist them to loosen them up, the pull them out.
Here is how you remove the light bulb tubes, they are held in via a crimp that we can not recreate, so you must drill the crimp off. I am using a 3/4" drill bit mounted in my drill press. You can also use a dremel, or a hand file if you want. You just need to remove the metal crimp and that is all. Attached image(s) |
Lo-Fi Version | Time is now: 26th May 2024 - 11:42 AM |
