Build your own Combo (904) Gauge, Parts 1 and 2 |
914forme |
Apr 23 2006, 06:48 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Well here it goes the step by step instructions on how to build one of the kits. Since I helped do the original production run, back in the day, its been about 11 years ago since we did these. But there is interest in it so I will show you how.
Step one, the original kit. It included a gauge face, a backing plate and a ground lug. Also included instructions on how to do this, and some of the items where real PITAs to do. I will included some changes I do, and items that might make the installation a little easier. Attached image(s) |
914forme |
May 7 2006, 05:42 PM
Now onto the cutting of the rear gauge face. There are two styles of gauge backs that you can be dealing with. The first is the early style. the second one is the late style they removed the extra top window. If you are using the late style you will need to drill out 2 extra holes for the backing plate mount. You will also need to tap these with a 3mm 0.5 tap. I suggest you do this before, you cut the back off.
Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 09:16 PM |
