Build your own Combo (904) Gauge, Parts 1 and 2 |
914forme |
Apr 23 2006, 06:48 PM
Well here it goes the step by step instructions on how to build one of the kits. Since I helped do the original production run, back in the day, its been about 11 years ago since we did these. But there is interest in it so I will show you how.
Step one, the original kit. It included a gauge face, a backing plate and a ground lug. Also included instructions on how to do this, and some of the items where real PITAs to do. I will included some changes I do, and items that might make the installation a little easier. Attached image(s) |
914forme |
Aug 8 2006, 04:04 PM
Next is the best part marking where you need to cut to get the idiot lights up and through the gauge faces. Rinse and repeat these steps 3 times. Then you cut around your pencil marks. I have a 1/2 in chassis punch I use to do this with, makes nice clean holes. But you can use a standard set of snips, or a nibbler to do this also. A file if you really wanted to, or a dremel if you have a steady hand.
Attached image(s) |
Lo-Fi Version | Time is now: 26th May 2024 - 09:58 AM |
