Build your own Combo (904) Gauge, Parts 1 and 2 |
914forme |
Apr 23 2006, 06:48 PM
Well here it goes the step by step instructions on how to build one of the kits. Since I helped do the original production run, back in the day, its been about 11 years ago since we did these. But there is interest in it so I will show you how.
Step one, the original kit. It included a gauge face, a backing plate and a ground lug. Also included instructions on how to do this, and some of the items where real PITAs to do. I will included some changes I do, and items that might make the installation a little easier. Attached image(s) |
914forme |
Aug 17 2006, 07:45 PM
And for the cliff hanger!
This cures a bunch of ills, like my one light tube being out of place, it is a postive mechanical fastener, and it is so easy, wish I came up with it 10 years ago. First you need to mark the center of the face, if you got one with out a hole. If your building one with a black center this might not work for you. Or it could, with a little camoflage work once you are done. (IMG:style_emoticons/default/biggrin.gif) Next you drill it just a little smaller than the outer face of your counter sunk machine screw. Then you counter sink the face. Next you drill the center of the back face, and here is the simple part you bolt it togther. Just use a rubber spacer ot keep the screw from grounding out any of the guage connectors. Attached image(s) |
Lo-Fi Version | Time is now: 26th May 2024 - 10:02 AM |
