cant open the engine lid...HELP! |
mchamner |
Aug 5 2006, 11:23 PM
myke Group: Members Posts: 6 Joined: 2-July 06 From: California Member No.: 6,356 |
Hi, does anyone have any suggestions on what i can do to open my engine lid?my 1975 (IMG:style_emoticons/default/WTF.gif) 914 been idle for a while and i was trying to start it back up again by putting a new battery in when.... The damn engine compartment lid knob/opener was stuck and now i cant open it! I tried greasing it and nada happend... please help!
mchamner |
Aug 5 2006, 11:56 PM
oh... if i jack the car up will the cable to open it be exposed? maybe i can just pull it from there and open it...thanks!
Elliot_Cannon |
Aug 6 2006, 01:00 AM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Hit the lid with the palm of your hand and press down while pulling on the knob. Might help. Might not but worth a try if you haven't already tried it.
Elliot |
wbergtho |
Aug 6 2006, 01:40 AM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
Open up the rear trunk and access the engine lid latch from the plastic cups located by each shock tower. Its no fun but doable.
highways |
Aug 6 2006, 02:19 AM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
Put the car on a rotissery and shake it upside down. Ok, it's a joke.
GWN7 |
Aug 6 2006, 03:31 AM
You can sometimes trip the latch from the top (Going thru the grill) by using a small screwdriver to push on the latch.
JPB |
Aug 6 2006, 05:58 AM
Just a small rap on the lid as you pull the nob will work. Leave the BFH alone for this one and don't forget to talk to it.
(IMG:style_emoticons/default/beer.gif) Make shure noone is listening though specially on them four letter words like, heat,snow,rain,fuel,road,damn rubr........ |
JoeSharp |
Aug 6 2006, 08:20 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The latch open
The latch closed Screwdriver in place to open the lid. Standing next to the car the screwdriver is pointed at your left foot, now push hard. :PERMAGRIN: Joe |
tod914 |
Aug 6 2006, 08:29 AM
Open the rear trunk lid and trigger the latch with a screw driver. Easy enough to get in from there. Might want to hit the latch with wd40 or pb blaster if its stuck.
cooltimes |
Aug 6 2006, 09:22 AM
Advanced Member Group: Members Posts: 2,508 Joined: 18-May 04 Member No.: 2,081 Region Association: None |
BMXerror |
Aug 6 2006, 10:00 AM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Open the rear trunk lid and trigger the latch with a screw driver. Easy enough to get in from there. Might want to hit the latch with wd40 or pb blaster if its stuck. This one gets my vote for the easy fast way. This is what I did, but I couldn't open the trunk at the time. I just WD40ed the latch from above, then slipped a screwdriver between the engine lid and the trunk to minipulate the latch. At the time I didn't know how the latch worked, so I looked at the few pictures in the manual to figure it out, then went out and popped it in about a minute. Mark D. |
Air_Cooled_Nut |
Aug 6 2006, 10:34 AM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
I found an unexpected way to open my engine bonnet just two days ago:
At a stop light, get some middle-aged, worn-out business man next to you in an older Lexus who keeps eye-balling you from the corners of his eyes while creeping forward at the light, trying to get the jump on you. It also helps to have a nice looking BMW behind you. When the light turns green, stomp on the accelerator and blow the doors off the Lexus. When you hit the other side of the intersection you'll shift into 2nd gear. That's when your engine lid will pop itself open (IMG:style_emoticons/default/rolleyes.gif) I can only hope everyone watching assumed it was an automatic wing ala Boxster to keep the car on the ground (IMG:style_emoticons/default/av-943.gif) |
GWN7 |
Aug 6 2006, 12:40 PM
Either that or they went "Look!! parts are flying off that thing" (IMG:style_emoticons/default/wink.gif)
mchamner |
Aug 6 2006, 03:36 PM
The latch open The latch closed Screwdriver in place to open the lid. Standing next to the car the screwdriver is pointed at your left foot, now push hard. :PERMAGRIN: Joe thank you..this helps i ton... ima try it right now... ill let you guys know the verdict after! (IMG:style_emoticons/default/smile.gif) |
mchamner |
Aug 6 2006, 03:57 PM
what i failed to mention is that the back lid wont open because it was replace with a solenoid which can only be opend if the car is started...damn this situation sucks...
Rrrockhound |
Aug 6 2006, 05:36 PM
Member Group: Members Posts: 192 Joined: 30-November 05 From: Delaware, OH Member No.: 5,213 Region Association: None |
I found an unexpected way to open my engine bonnet just two days ago: At a stop light, get some middle-aged, worn-out business man next to you in an older Lexus who keeps eye-balling you from the corners of his eyes while creeping forward at the light, trying to get the jump on you. He wasn't trying to get the jump on you, he was hitting on you. Duh! |
jwalters |
Aug 6 2006, 05:49 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
OK, first off you need a special tool to be carried around at all times.
Do you like chinese food??? Cause that is where you get the tool from. When you have your tool, you simply insert it ................................ (IMG:style_emoticons/default/drunk.gif) |
mchamner |
Aug 6 2006, 08:15 PM
YEAY! I got it open with the screwdriver eventually... The engine was cranking real nice but it wasnt turnin over... I could smell gas so its prob the spark plug... Ima tow it in to the mechanic this week... ill keep u guys posted...
Lo-Fi Version | Time is now: 13th May 2024 - 08:52 AM |
