Question on autocrossing, suspension adjustments |
jwalters |
Aug 6 2006, 01:43 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:style_emoticons/default/idea.gif) Got a question concerning the front end pushing through the corner -
Have factory stock front and rear sway bars and running cookies with 225-60 series tires. My front end tends to push when cornered aggressively. Not too bad, but I can certainly detect a loss of weight transfer to the outside front. Seems as if my setup has the suspension too stiff, if that is possible. What would be the outcome of disconnecting a bar altogether?? (front or rear) Have tried adjusting air pressures and there is a very slight noticeable gain in traction, but slight non-the-less. Gonna try out a SOLO II next month and am curious as to what the in-the-knows think. (IMG:style_emoticons/default/happy11.gif) |
DanT |
Aug 6 2006, 03:47 PM
sway bars....stock?
torsion bar size front, spring rate rear. alignment settings shock type....adjustable konis, bils, kybs? |
JPB |
My dad had a Buick Century which when hitting the gas and turning the wheel hard, the outside fender rolled way up and the other hard down and it seemed like the damn thing wated to role over.LOL It drove like a water bed! I hope you are saying your car runs to flat around corners.LOL If it rides to stable and I hope it does, since I will have the same setup, my suggestion is you are driving to slow!!!!LOL
(IMG:style_emoticons/default/beer.gif) Hammer down till it slides! |
ft.lbs. |
Aug 6 2006, 04:06 PM
Newbie Group: Members Posts: 41 Joined: 30-December 04 From: Jefferson,ME. Member No.: 3,376 |
Simple front sway bar adjustment.My fathers 914 was doing the same thing.
JPB |
Aug 6 2006, 04:10 PM
Joe Ricard |
Aug 6 2006, 04:56 PM
You adjust them right out of the car. and get an adjustable one.
I did more streeting with the gas pedal last night on a wet Autocross course than I ever have before. Hankook RS-2 rock in the wet. |
Trekkor |
Aug 6 2006, 05:08 PM
You need to create more grip in the front.
It became very clear to me yesterday with lower treadwear compound tires on the rears. It was impossible for me not to oversteer. That being said, you can try some of these ideas: Run the tire pressures higher in the front/lower in the rear. If you are on street tires, maybe 37/32 fr/rear or 35/33 if you want to be a little more conservative. You can try disconnecting the front bar altogether. Lower the front end. http://rogerkrausracing.com/overundr.html KT |
jwalters |
Aug 6 2006, 05:36 PM
sway bars....stock? torsion bar size front, spring rate rear. alignment settings shock type....adjustable konis, bils, kybs? Yea stockers outta a '73 for bars stockers for torsion 140# progressives on the rear Factory alignment specs Because it is a street driven ride I cannot do too much to it other than what it already has. |
jwalters |
Aug 6 2006, 05:39 PM
My dad had a Buick Century which when hitting the gas and turning the wheel hard, the outside fender rolled way up and the other hard down and it seemed like the damn thing wated to role over.LOL It drove like a water bed! I hope you are saying your car runs to flat around corners.LOL If it rides to stable and I hope it does, since I will have the same setup, my suggestion is you are driving to slow!!!!LOL (IMG:style_emoticons/default/beer.gif) Hammer down till it slides! Hehe, reminds me of my buddies '72 Olds 442 with a full tilt 455 Rocket Propelled engine up front. He built it for the street. 675 dyno'd HP and 710 ftlb torquer BEASTY. His car's body has a permanent twist in it now --------- Yea, my car has almost no body lean at all. Stays unreal flat around the curves --- |
jwalters |
Aug 6 2006, 05:44 PM
You need to create more grip in the front. It became very clear to me yesterday with lower treadwear compound tires on the rears. It was impossible for me not to oversteer. That being said, you can try some of these ideas: Run the tire pressures higher in the front/lower in the rear. If you are on street tires, maybe 37/32 fr/rear or 35/33 if you want to be a little more conservative. You can try disconnecting the front bar altogether. Lower the front end. http://rogerkrausracing.com/overundr.html KT When I got it aligned the body was neutral. I have it dropped about 3 inches up front (so much so I tore of the lower lip of my front flares from the tread eating it out <AND> has made steering HYPERSENSITIVE to say the least, gotta really concentrate hard when on the interstate going 90) My tires are those new generation high pressure ones. Mine calls for 45 psi normal. I have tried as low as 36 and the squirm was unreal so I had to go back up to 42. From that point I really cannot tell a difference between 42 and 45. |
Trekkor |
Aug 6 2006, 05:49 PM
Well then, those tire may just be the limiting factor between you being able to drive to a higher limit at the a/x.
You cannot exceed the limit. None of us can (IMG:style_emoticons/default/wink.gif) KT |
jwalters |
Aug 6 2006, 05:52 PM
Well then, those tire may just be the limiting factor between you being able to drive to a higher limit at the a/x. You cannot exceed the limit. None of us can (IMG:style_emoticons/default/wink.gif) KT (IMG:style_emoticons/default/shocked[1].gif) |
Aug 6 2006, 05:53 PM
Resident German Group: Admin Posts: 41,633 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have it dropped about 3 inches up front (so much so I tore of the lower lip of my front flares from the tread eating it out <AND> has made steering HYPERSENSITIVE to say the least, gotta really concentrate hard when on the interstate going 90) there's your problem, you're running out of suspension travel ... also, to make the front grip more, drop the tire pressure in the front. or, make the rear more lose by adding some pressure in the rear ... of course, these are all only bandaids until you get around to get the right (read: adjusteable) components and start from scratch (on your setup that is) ... (IMG:style_emoticons/default/smile.gif) Andy |
jwalters |
Aug 6 2006, 06:13 PM
I have it dropped about 3 inches up front (so much so I tore of the lower lip of my front flares from the tread eating it out <AND> has made steering HYPERSENSITIVE to say the least, gotta really concentrate hard when on the interstate going 90) there's your problem, you're running out of suspension travel ... also, to make the front grip more, drop the tire pressure in the front. or, make the rear more lose by adding some pressure in the rear ... of course, these are all only bandaids until you get around to get the right (read: adjusteable) components and start from scratch (on your setup that is) ... (IMG:style_emoticons/default/smile.gif) Andy So true, so true |
JPB |
Aug 6 2006, 06:21 PM
Schweettt! Those tires would be hell to use at an autoX. Okay, heavier front sway bar and hard springs in the back would be ideal but for stock, it might be good with them sticky tires? Hey just hoping here since thats what I got right now. We can still drown Miatas right?
(IMG:style_emoticons/default/beer.gif) |
jwalters |
Aug 6 2006, 06:32 PM
Schweettt! Those tires would be hell to use at an autoX. Okay, heavier front sway bar and hard springs in the back would be ideal but for stock, it might be good with them sticky tires? Hey just hoping here since thats what I got right now. We can still drown Miatas right? (IMG:style_emoticons/default/beer.gif) Dude, I went to one just to watch. I rolled up in BlackSabbath and heard mutterings of the like of: "OH S*#T!" "HOLY F#$K" and the one I liked the most: "Well that does it, lets pack it in before we get our asses handed to us" (IMG:style_emoticons/default/happy11.gif) I thought it quite strange for such comments coming from dudes in vipers, a GT3R, about a dozen corvettes, a couple of ferraris, and a whole slewwwww of rice burners. Hey, they don't know I am packing all of 85HP so who am I to point it out - Was good to watch them in action tho anyway --- |
JPB |
Aug 6 2006, 06:44 PM
(IMG:style_emoticons/default/happy11.gif) I thought it quite strange for such comments coming from dudes in vipers, a GT3R, about a dozen corvettes, a couple of ferraris, and a whole slewwwww of rice burners. (IMG:style_emoticons/default/av-943.gif) Black Sabbath them back to their momas! (IMG:style_emoticons/default/aktion035.gif) SChweeeeet! |
Lo-Fi Version | Time is now: 12th May 2024 - 02:41 PM |
