Anyone with Type 3 experience, bidding on this squarback |
Mike D. |
Aug 7 2006, 11:48 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I'm bidding on this squareback to pull behind the RV. I figure it can't be that different than working on a teener. Right?
Nice Type 3 |
lapuwali |
Aug 7 2006, 12:00 PM
Looks nice, much nicer than my '69 Square. If the price doesn't climb too much more, that's also a good deal. Carbs were stock on the '67, but so was the swing axle rear suspension. In '68 or '69, they went to IRS and FI (similar, but not identical, to the D-Jet on the 914). They carry a lot, and will cruise nicely at 70mph. With FI, they get about 26mpg at that speed. I don't know how well they do with carbs.
They're generally pretty easy to work on. Valve adjustments are very slightly easier on the Type 3, as the HEs and the rear suspension aren't quite as much in the way. Check for rust in the floorpan under the battery (under the rear seat). |
Cap'n Krusty |
Aug 7 2006, 12:31 PM
Great cars! I can tell you from personal experience you can roll 2 drums of oil int the back and still motor on down the highway! Better mileage than the bug, more comfortable, and much more stylin' I've owned more than a few in my time. The Cap'n
drewvw |
Aug 7 2006, 01:19 PM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
I had a squareback in college....never really ran right but that was mostly my fault. I would definitely buy one.... |
Bleyseng |
Aug 7 2006, 01:39 PM
I have had 2, a 64 1500S SB and a 69 Fastback. The SB I hotrodded to a 1776cc with all the goodies and it flew. Used it for a DD and a ski rig cuz you could crawl in the back and sleep or go camping.
The 69 FB with Djet got 30mps easy and on the long hauls it got 40mpg in the gas crunch days. Yep, look for rust under the battery and in the front body to pan areas under the wheelwells. |
BenT |
Aug 7 2006, 01:48 PM
realty check casher Group: Members Posts: 103 Joined: 21-June 06 From: San Francisco Member No.: 6,273 Region Association: None |
I'm bidding on this squareback to pull behind the RV. I figure it can't be that different than working on a teener. Right? Nice Type 3 I've been a serial Type 3 Owner. I owned mostly Notchbacks but had squarebacks as well. The Type 3 engine is essentially a Type 1 (bug & ghia) engine with the cooling fan on the tailend similar to the 914. The difference in the engine case is an extra hole for the rear mount and a hole for the dipstick at the bottom corner. Most Type 3 enthusiasts prefer the 67 because it was the first year for the dual port IIRC, last year for the swingaxle (factory sway bar was added to tame neg. camber). It was got the better balljoint suspension. The later IRS can be added with moderate difficculty. The whole rear trailing arm systems can be transplanted along with brakes, etc. Rear upper motor mount becomes obsolate but two side mounts need to be added. Oh yeah, teener wheel bolt pattern is the same. If you are ambitious, you can bolt up a Type 4 teener motor in the same bellhousing. I once broke down in my 68 Type 2 camper in Sacramento Valley. It was full of furniture. My ex came up from SF with my 68 Type 3 wagon. We towed the whole shebang some 30 miles up to Lincoln, CA at about 65 MPH with the Type 3. Type 3's do not accept tow bars up front as easily as the Type 1's. They have flat/squarish torsion bar tubes. If you plan to tow this behind an RV, you'll need to buy or make tow bars to fit the bumper mounts. Go to Type3.org for more info. BenT vanagoncafe.com |
Air_Cooled_Nut |
Aug 7 2006, 02:00 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Late models are even better IMHO. IRS (Independant Rear Suspension), more aerodynamic, better front disc brakes, and fuel injected (D-jet). If you look at getting an automatic you will NOT be able to tow it with the rear wheels on the ground, it WILL require a trailer...or else you can remove the axles if you insist on towing with the rear wheels on the ground (IMG:style_emoticons/default/sad.gif)
T3-specific parts are more difficult to come by than Type I's and II's (Bugs and Buses) |
Air_Cooled_Nut |
Aug 7 2006, 02:03 PM
Looks like it sold just shy of $4000. Without seeing the car it seems like a fair deal.
JoeSharp |
Aug 7 2006, 04:07 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Mike: I had a Squareback that I put 300K miles. 3 engines and trannys, towed a catamaran all over (S.F. the river Mexico). Great cars. Mine got 48 mpg once and it had a 22 gallon tank in the trunk above the stock one. Easer to mantain than any of the cars you have now.
:EPRMAGRIN: Joe |
Mike D. |
Aug 7 2006, 04:34 PM
Joe, I figured you might chime in sooner or later. I let that go at the end, I know it was probably a good deal. But sight unseen and no PPI, eh, you know. I'd feel better inspecting one myself, maybe out at Pamona or something more local. I'd also rather have a later one with the FI. and IRS.
Thanks for the input, I'm going to keep looking, but no more e-bay... |
JoeSharp |
Aug 7 2006, 04:46 PM
Mike: I'm with you. I like to see what I'm buying. When you want to look at a car let me know.
:PERMAGRIN: Joe |
Air_Cooled_Nut |
Aug 8 2006, 09:39 AM
Additional model info:
http://www.thesamba.com/vw/forum/viewtopic.php?t=78049 |
BenT |
Aug 8 2006, 12:23 PM
Mike: I'm with you. I like to see what I'm buying. When you want to look at a car let me know. :PERMAGRIN: Joe I feel the same way part of the time. It will depend on what I am buying and for what price. If someone told me they had a 1973 914 for $5000 I am going to want to see it. If someoe offered me a 1970 914-6 for $7500 w/o any dents, runs well, and currently registered, I would probably agree to buy it before seeing it. I did a couple of months ago. I prefer the 69 Type 3 with vs. the 67. My point earlier was that most Type 3 enthusiasts are big on the 67. BenT |
Lo-Fi Version | Time is now: 14th May 2024 - 12:02 AM |
