Shift lever adjustment, To the left or to the right? |
Elliot_Cannon |
Oct 19 2003, 05:41 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Hi,
My 73 has been giving me trouble shifting into 4th gear lately. Mostly after it has been warmed up awhile. All the bushings have been changed. I want to adjust the shift lever but have read two different procedures. The Pelican Tech. Site says to adjust the forward shift rod with the shift lever all the way to the left. Haynes and Pat Paternies book say to adjust it with the shift lever all the way to the right stop. Which is the correct method? My new engine doen't like it when I shift into 2nd instead of 4th. Cheers, Elliot |
ArtechnikA |
Oct 19 2003, 05:49 PM
QUOTE(Elliot Cannon @ Oct 19 2003, 03:41 PM) ...Pelican Tech. Site says to adjust the forward shift rod with the shift lever all the way to the left. Haynes and Pat Paternies book say to adjust it with the shift lever all the way to the right stop. Which is the correct method? the way that works ... both those methods are good for getting you in the ballpark. another way is - put the transmission in 2nd, put the lever in the middle, forward, tighten things down. the documented procedures are just to provide a reference (a stop) and the associated transmission gear. after that, you just move the rod a spline at a time (if you have trouble matching the gates) or a bit forward or aft (if you have trouble fully engaging a gear set) until it all works with your car. |
redshift |
Oct 19 2003, 06:26 PM
I always adjust in 2nd.
M |
Elliot_Cannon |
Oct 19 2003, 08:11 PM
Thanks guys, It looks like a few different methods to do this. I'll just try them all till I find one that works.
Cheers, Elliot (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 07:26 PM |
