SIX Conversions - Any with AC?, Looking to do a 3.0 w/AC |
3d914 |
Aug 9 2006, 06:16 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
I'm looking to do a 3.0 six, but need to maintain the AC from the four. Likely I'll need a different compressor and mounting scheme, but anyone BTDT?
TIA, |
lapuwali |
Aug 9 2006, 06:26 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
You should be able to find a 3.0 with an AC compressor already attached. Since you already have the condensor and all of the plumbing in the /4, you're most of the way there. The compressor on the 911 is typically mounted next to the cooling fan on what will be the driver's side when it's installed in the 914. You'll need to move the engine bay A/C hoses over , and maybe get the fittings changed by a shop that specializes in A/C work.
It's possible that you could drive the compressor you have now. You'd need to fabricate brackets to attach it to the engine, and you'd need an A/C crank pulley for the engine (if it doesn't already have one). You MAY even be able to mount it on the passenger's side of the engine (the SC air pump normally mounts there), which would mean it would be positioned very close to the current location in the engine bay, so the rest of the plumbing wouldn't need as much work to adapt. This will almost require you to retain the CIS injection system, too. Carbs would foul any reasonable mounting location for the compressor. |
grasshopper |
Aug 9 2006, 06:27 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
I dont know much about it, but I think I remember reading somewhere, that the compressor hits the firewall, and some had to be removed, or moved back...
ClayPerrine |
Aug 9 2006, 06:55 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The 911 compressor mounts can't be used in a 914 unless you put a big dent in the firewall to clear the compressor. But that will distort the backpad and limit the rearward travel of the driver's seat.
You need something like this: I created this for my 914/6 conversion. It allows you to put the compressor in almost the same location as in the 4 cylinder cars, plus it makes changing the belt extremely easy. No more fooling with the shims behind the fan pulley. |
grasshopper |
Aug 9 2006, 07:01 PM
Awsome! (IMG:style_emoticons/default/clap56.gif) Now I can put AC in my car. Where did you get the belt?? Custom made?
ClayPerrine |
Aug 9 2006, 07:26 PM
The compressor mount is custom made. The belt is an off the shelf item at FLAPS. The pulleys come from Clewett engineering. The idlers and the compressor come from IceAc. The tensioner is a timing belt tensioner for a Nissan 300ZX motor.
I added a vertical bracket to the Rich Johnson nosecone mount and installed the idler pulleys. The compressor mount sits over the valve cover, and 2 tall spacer nuts replace the valve cover nuts. I am going to make a second version that uses aluminum, and a automatic tensioner. But this version is on my car and running. When I first got it running, I had a problem with pulley alignment, and it ate a belt. I changed the belt in a parking lot in a business suit and tie, in less than 10 minutes, without getting anything but my fingers dirty. The only tool I used was a 13mm wrench to loosen the tensioner. Try that on a standard 914/6 belt setup. The only bitch I have with it is that you have to pull the compressor to change the #1 spark plug. I am going to rework that in the second version. More picts... Pulleys close up: Compressor and Tensioner close up: Rear of the compressor mount: I later drilled a hole in the bracket above the spark plug. The bracket pushed on the plug wire and damaged the top of it. |
3d914 |
Aug 9 2006, 07:33 PM
Thanks James & Clay,
Clay - excellent little engineering job there. Its great to see something that's designed to worked from those who have to use it. I hope you'd be willing to make the plans for such bracket available at a reasonable cost, or better yet manufacture & sale them. Keep us posted, and I'll be getting back with you when I get to that point. Regards, |
grasshopper |
Aug 9 2006, 07:34 PM
Awsome!! (IMG:style_emoticons/default/clap56.gif) So I am assuming the tensioner is not adjustable?? If I am using a stock 914-6 engine mount, do you have any idea how I would mount the pulleys??
grasshopper |
Aug 9 2006, 07:37 PM
BTW, how much stress does the compressor put on the valve cover studs??
lapuwali |
Aug 9 2006, 07:50 PM
Clay, that is absolutely awesome. If I needed A/C here (it maybe hits 90dF about 3 times a year), that's how I'd do it.
pete-stevers |
Aug 9 2006, 07:52 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
clay can you post so pics of the cooling coil and its mounting as well??
ClayPerrine |
Aug 9 2006, 07:54 PM
Awsome!! (IMG:style_emoticons/default/clap56.gif) So I am assuming the tensioner is not adjustable?? If I am using a stock 914-6 engine mount, do you have any idea how I would mount the pulleys?? The tensioner is adjustable. The 300ZX timing belt tensioner has an off center hole and a 6mm hex head hole in it. Just loosen the nut and turn it with a 6mm allen wrench. But I have found that by doing that, you can get the belt too tight. It's better to just turn the tensioner with your hand and tighten up the nut. BTW, how much stress does the compressor put on the valve cover studs?? Almost none. Everyone who has seen it loves the idea. The only down side is you have to put in 8mm studs in place of the 6mm ones that go through the timing cover. |
Gary |
Jan 17 2009, 07:16 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Hey Clay,
Any further plans for a V2? I've a got a 3.2 that needs to go in over the winter. It would be great to do this up while the motor's out (IMG:style_emoticons/default/aktion035.gif) . |
ClayPerrine |
Jan 17 2009, 11:06 PM
Actually, no. I have been working on a new motor and getting the evaporator setup in the car.
Picts to follow for that one. I have no problem with you duplicating what you see in the pictures. |
Gary |
Jan 18 2009, 12:08 AM
Thanks - I wish... No welding skills.
highways |
Jan 18 2009, 04:03 AM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
Thanks - I wish... No welding skills. welding skills= 5 hours internet research on proper "MIG" welding technique, 4 hours practice on scrap, and 3 hours part fabrication with good quality borrowed MIG welder. That bracket looks pretty substantial though... 110V welder might not cut it? Might need 230V power supply? Any thoughts from the more experienced out there? |
degreeoff |
Jan 18 2009, 07:59 AM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
Hell, my 110 welds up to 1/4 no sweat...you are good with one. I did my whole car with a 110 including roll cage
Josh |
ClayPerrine |
Jan 19 2009, 10:53 AM
Thanks - I wish... No welding skills. welding skills= 5 hours internet research on proper "MIG" welding technique, 4 hours practice on scrap, and 3 hours part fabrication with good quality borrowed MIG welder. That bracket looks pretty substantial though... 110V welder might not cut it? Might need 230V power supply? Any thoughts from the more experienced out there? I welded it up with a 110v MIG. (IMG:style_emoticons/default/smile.gif) |
Maltese Falcon |
Jan 24 2009, 01:21 AM
Advanced Member Group: Members Posts: 4,658 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Gary |
Jan 24 2009, 09:34 AM
I wonder how much bulkhead modification would need to be done without that double pulley on the compressor. Looks like a big ole York.
I have a nice Sanden - just need a way to mount it. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:01 AM |
