Oil Filter Wrench, What do you use??? |
jgara962 |
Aug 9 2006, 08:28 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
Okay, let me just say up front that these are probably two lame questions.
1. What do you use to take the oil filter off?? I've got three f'ing wrenches in the garage and none of them work! Two of them you can't even get on the oil filter because of the location, and the other one (type that grips from the bottom) won't grab the Mahle filter. Not sure how in the hell I managed to get it off last time (IMG:style_emoticons/default/dry.gif) 2. This one is really dumb, but I'll dare to ask it. My 914 spends a good part of its life in the garage. This is the first car I've owned that isn't a daily driver. So for changing the oil, how relevent is the 3 months or 3,000 mile thing? All my past cars, you just take in at 3 months or 3,000 miles - no big deal. Over a three month period, I may only drive it a couple hundred miles. Hell, I've only put on 1,500 miles since I bought it over a year ago. So for you guys in a similar situation, how often do you change your oil? Thanks (IMG:style_emoticons/default/biggrin.gif) |
Matt Romanowski |
Aug 9 2006, 08:36 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I use the plier type wrench to take it off.
As far as frequency - drive more!! I would say you can go 3,000 miles or 6 months. After that long, the oil will start building higher acid levels and it can etch bearings, etc. Some people will argue the 3,000 miles, but it is the number I use. Matt |
grasshopper |
Aug 9 2006, 08:55 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
I take a screwdriver and stab the oil filter and unscrew it. (IMG:style_emoticons/default/chairfall.gif) I'm completely serious. I'm a redneck. (IMG:style_emoticons/default/ar15.gif)
ClayPerrine |
Aug 9 2006, 09:14 PM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I use a BIG ASSED pair of channel locks to grab the filter.
And I am not as much of a redneck as grasshopper. |
jgara962 |
Aug 9 2006, 09:32 PM
Nevermind. I was just about ready to call it quits for the night, and I found TWO more oil wrenches in my tool box. Both the clamping kind - one large and one small. You'd think I was running a Jiffly Lube out of my garage (IMG:style_emoticons/default/blink.gif) No idea how I ended up with five different filter wrenches but oh well.
grasshopper |
Aug 9 2006, 09:39 PM
And I am not as much of a redneck as grasshopper. I wonder which state has more redneck...GA or TX????? Naw, thats an easy one...Georgia by a LONG shot. (IMG:style_emoticons/default/chairfall.gif) |
SGB |
Aug 9 2006, 09:41 PM
Dang barbarians. I've got a big 16 (or wjatever) sided cup-like thing that uses a socket wrench and extention to take off the filter. I disagree with the redneck screwdriver method. Filters are made of such thin metal that the screwdriver well not rotate the filter, but instead tear and shred all the way downn to the base
SLITS |
Aug 9 2006, 09:44 PM
And I am not as much of a redneck as grasshopper. I wonder which state has more redneck...GA or TX????? Naw, thats an easy one...Georgia by a LONG shot. (IMG:style_emoticons/default/chairfall.gif) Nah, you got CRACKERS / PEACHES / PRALINES / ...... Texas has LONG HORNS / LONG NECKS / AGGIES....... RedNecks are smarter than all of those................. |
914fan |
Aug 9 2006, 10:34 PM
Member Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 |
A LONG time ago when I worked at Seras. I bought an oil filter wrench that was the coolest thing ever. You put the retchet on it and as you turn left (remember lefty loosy) it clamps down from 2 sides with these V chanel things. When it has a good bite on it you just keep turning left and it will loosen the filter. The best part is the tighter the filter is on the car the tighter the thing grabs. I had it CRUSH a filter until the filter let loose. A great toy.
This would work, http://www.sears.com/sr/javasr/product.do?...UseBVCookie=Yes But this is what I have. http://www.holden.co.uk/productimages/095_819.jpg Except mine is Craftsman. Good luck. |
Bruce Allert |
Aug 9 2006, 11:47 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Pussies.....
ya jes' gab it wit yer hand & twist it off (IMG:style_emoticons/default/drunk.gif) .....b (IMG:style_emoticons/default/biggrin.gif) |
dlo914 |
Aug 10 2006, 01:51 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
i 2nd the screw driver technique. it's works just as well when i can't find the oil filter plier.
DBCooper |
Aug 10 2006, 04:18 AM
i 2nd the screw driver technique. it's works just as well when i can't find the oil filter plier. Be sure to lube the rubber gasket before putting the new filter on. If you don't overtighten it it'll come right off the next time. And I'd suggest that you use the screwdriver technique only as a last resort. What happens if you've jabbed the filter, the canister tears, and still can't get it off? Car's going nowhere. That may be an acceptable possibility if it's your own car and you like seeing it on jackstands in the garage, but it's totally unacceptable if it's a customer's car. |
Lo-Fi Version | Time is now: 13th May 2024 - 02:47 PM |
