Compression test, maybe not good news |
EJP914 |
Aug 11 2006, 07:54 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Have just been told by mechanic who checked compression on my "73 1.7 that results are as follows:
#1 100 psi #2 120 psi #3 120 psi #4 150 psi He is recommeneding valve job. I know the readings are all over the place, but is this guy correct? Car was in for valve adjustment, had a small miss around 2800 RPM, and backfired when decell. Timing and fuel mixture were adjusted. BAckfire almost gone. I noticed during last oil change some black soot on the head around the exhaust pipe on the left front cylinder. I suspect this is a small exhaust leak. Would this have any bearing on the compression reading for that cylinder? I would appreciate any and all thoughts on this. Don't want to put out the bucks right now for valve job, but may have to if that is the cure. Thanks for listening! |
G e o r g e |
Aug 11 2006, 08:35 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
QUOTE Ah, George- stop baggin on the new guy! Three minutes is a long wait for a response around here... ok john i'm sorry how about a little (IMG:style_emoticons/default/icon_bump.gif) for the first post Oh yea (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 03:09 PM |
