Speaker cover screws, What size are they? |
type4org |
Aug 12 2006, 08:19 AM
You need PLAID! Group: Members Posts: 231 Joined: 13-June 06 From: Oldenburg (Oldb), Germany Member No.: 6,212 |
I just received a beautiful set of original speaker covers and was wondering what size the mounting screws need to be. I'm not looking to fulfill some concours requirement, just making sure I don't buy them too long or too thick and wear out the screw holes in the body (IMG:style_emoticons/default/wink.gif)
boxstr |
Aug 12 2006, 11:47 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
What is the proper srew slot placement for the speaker cover screws?
CCLINCW |
tod914 |
Aug 13 2006, 05:51 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
See if you can download the PET CD.. it's on the site somewhere.. gives you every part, part number and description. Invaluable tool. It should tell you the sizes for those screws and if they are available. Do a search for it, it should come up.
type4org |
Aug 14 2006, 04:43 PM
See if you can download the PET CD.. it's on the site somewhere.. gives you every part, part number and description. Invaluable tool. It should tell you the sizes for those screws and if they are available. Do a search for it, it should come up. Tried a few search combinations, no luck (IMG:style_emoticons/default/sad.gif) |
Pat Garvey |
Aug 14 2006, 07:30 PM
See if you can download the PET CD.. it's on the site somewhere.. gives you every part, part number and description. Invaluable tool. It should tell you the sizes for those screws and if they are available. Do a search for it, it should come up. Tried a few search combinations, no luck (IMG:style_emoticons/default/sad.gif) Mine are orig - I'll pull in & try to measure it (never been too good with that stuff, but I'll try). |
Pat Garvey |
Aug 15 2006, 05:52 PM
Jens,
Mine are from a '72 & no reason to think it would have changed thru the years. Thay are half-round, chrome, 4mmx8mm. No reason to believe that stainless wouldn't work & you need acceptable washers too. Hope that helps. (IMG:style_emoticons/default/biggrin.gif) |
type4org |
Aug 15 2006, 06:08 PM
Thay are half-round, chrome, 4mmx8mm. No reason to believe that stainless wouldn't work & you need acceptable washers too. Thanks a bunch Pat (IMG:style_emoticons/default/smile.gif) I got lucky today when I ripped out the ugly speakers: Looks like I do have at least 3 out of the 4 screws needed for each side. They must have been put back into their original screw holes when the first owner switched the speakers. |
tod914 |
Aug 15 2006, 10:17 PM
PM your email and ill send u that PDF PET file.
rhodyguy |
Aug 22 2006, 07:11 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
my old aa catalog shows 2 #s.
front side-TAPPING SCREW, CSK, RAISED HEAD B4.8x22, 900 145 053 07 rear side- TAPPING SCREW, CSK RAISED HEAD B4.4.8X16, NO 140 986 |
type4org |
Aug 22 2006, 09:15 AM
front side-TAPPING SCREW, CSK, RAISED HEAD B4.8x22, 900 145 053 07 rear side- TAPPING SCREW, CSK RAISED HEAD B4.4.8X16, NO 140 986 Thanks - I was able to make do with the screws I found in the car. All I am missing is the bottom screw on each side, but the cover is held secure by three screws now, I'm not too worried about it. |
914runnow |
Aug 23 2006, 10:36 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
I just received a beautiful set of original speaker covers and was wondering what size the mounting screws need to be. I'm not looking to fulfill some concours requirement, just making sure I don't buy them too long or too thick and wear out the screw holes in the body (IMG:style_emoticons/default/wink.gif) Stoddards will have the black OEM replacements.. The Chrome are gone... I have a set...Anything to trade?? |
type4org |
Aug 24 2006, 03:41 AM
tod914 |
Aug 24 2006, 10:44 AM
Get the PDF?
type4org |
Aug 24 2006, 10:50 AM
tod914 |
Aug 24 2006, 10:17 PM
Lo-Fi Version | Time is now: 19th May 2024 - 11:19 AM |
